Thread: Wrinkles in pool liner walls
    Hey guys, I've got a 4 year old AGP that's developed wrinkles in the liner on the walls of the pool. Any ideas what causes this or how I can fix it? I think it's a unibead liner.
    24' AGP, 54" - 13,300 Gallons at 47".
    AquaRay Cleaner
    Hayward Swimpro Voyager Filter/2 Speed 2 HP Pump
    PaulfromCT's Avatar
    Sep 2013
    Connecticut
    27
    Re: Wrinkles in pool liner walls
    Are the wrinkles towards the bottom of the wall down by the cove?
    24' X 54" round AGP with Uni-Bead Portofino Liner - 25 Gauge, partially in-ground. Hayward Perflex EC-40 D.E. Filter System 1-HP Power-Flo Pump. Installed Spring 2014.
    Casey's Avatar
    SW PA
    10,448
    Looks like water behind the liner to me. Wrinkles are creases. Those look puffy, indicating water.
    Apr 2013
    Sacramento, CA
    2,769
    I'm agreeing with Casey that looks like water. How high is the groundwater around your pool? Do you have dry wells or a drain system?
