Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: What does "aerate to increase pH"
    Jul 2016
    tulsa,oklahoma
    33
    I recently replaced about 40% of my water and new results show my TA is 100.
    According to PoolMath, I need to lower my TA by decreasing pH 7.0-7.2 with acid, and then aerate to increase pH.
    How do I "aerate"?
    Thanks
    32,000 gallon IG plaster (redone in 2003)
    Filter: Triton II sand
    Pump: Pentair Challenger 1 HP
    Test Kit: Taylor 2006
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    Re: What does "aerate to increase pH"
    Do you have a return side sprinkler or fountain that you attach to your water return port?
    I ended up making one out of 1.5" PVC that I drilled small holes in.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2014
    Houston tx
    2,525
    Any water feature will aerate your water or you can point your returns up so they move the surface of the water.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    or you can do it the fun way and throw a bunch of friends and family in the pool to splash around!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Aug 2014
    Houston tx
    2,525
    So true northrn!
    Marla
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Quote Originally Posted by poolbrush View Post
    How do I "aerate"?
    Thanks
    What is your PH now? You may not need to lower your TA if your PH is stable.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2016
    tulsa,oklahoma
    33
    Quote Originally Posted by Marlahoutex View Post
    I don't believe my returns moveable.
    What is a water feature?
    Quote Originally Posted by AimeeH View Post
    7.6 and has been for several days in a row
    Aug 2014
    Houston tx
    2,525
    Any type of water falling into your pool that makes the water move.
    Marla
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    A water feature can be a slide that has water running down it, and falling into the pool, a fountain, waterfall... anything that disturbs the surface of the water, and creates bubbles will work.
    Jul 2016
    tulsa,oklahoma
    33
    Quote Originally Posted by RonsPlc View Post
    i don't have anything like that. I'm pretty good at making stuff though.
    Not that Ive looked real close, but I don't recall the return jets lending themselves to having something attached to them.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    If your PH is stable, I wouldn't worry about TA at this point. If your PH starts climbing consistantly, the you might want to tackle lowering the TA.
    Jul 2016
    tulsa,oklahoma
    33
    Just restested my water and pH is up from 7.6 to 7.7 and TA up from 100 to 130. . We have had 1.5 inches of rain overnight ( I estimate that to be about 240 gallons of rainfall added to my pool)
    Complete test:
    FC- 1.6
    CC-0.4
    pH- 7.7
    TA-130
    CH-210
    CYA-35
    Jul 2016
    tulsa,oklahoma
    33
    Ok, I understand now. I will construct something out of PVC.
    mas985's Avatar
    Pleasanton, CA
    11,742
    You can also just point the returns toward the surface. It just takes a little longer.
    Mark
    Jul 2016
    tulsa,oklahoma
    33
    How or why does aerating raise pH.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    The out gassing of carbon dioxide from the water raises PH.
    Jul 2016
    tulsa,oklahoma
    33
    Quote Originally Posted by pooldv View Post
    what does out gassing mean? And/or how did CO2 get into the water?
    DFW, TX
    24,514
    Outgas is when gas moves out of a substance, like water. Carbon dioxide dissolves from the atmosphere into the surface of the water.
    Jul 2016
    tulsa,oklahoma
    33
    Interesting. Lotta chemistry going on out there that I really never considered. Thanks.
  20. Back To Top    #20
    DFW, TX
    24,514
    Oh yeah, one giant high school chemistry class.
