Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: Ready to SLAM!
    Jun 2016
    Mechanicsburg, PA
    66
    Ready to SLAM!
    Some of you may remember me on here and my 5 year battle with mustard algae. Well I am finally ready to eradicate it once and for all. Weather is cooling off here and it's on the weekend which will give me the break I need. Will post numbers tomorrow evening before I start. Just a few questions though before I begin. #1-since this stuff has been chlorine resistant from 12-18ppm at times, should I maintain a target higher then recommended once I am done with SLAM? #2-Should I be using the SWG to help maintain shock level once I get it there? I do need to sleep at some point lol. Any comments appreciated.
    17,200 in ground pool, DE filter,3/4 hp pump, solar heater, SWG (Hayward Salt and Swim 3C). 1988 Hot Springs Highlife-K Hot Tub (415 gal.)
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Ready to SLAM!
    Hi there
    Can you tell us how you are testing your water and post up a full set of results?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Using the Taylor K-2006. Will be posting numbers tomorrow eve before I start
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Ready to SLAM!
    It would be great to get a baseline. Have you tested your CYA recently?
    We're here to help which is why I asked. .
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Last time I checked it was 70 which was last week
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,390
    Re: Ready to SLAM!
    How much chlorine do you have on hand to get you started?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    Re: Ready to SLAM!
    No problem using the SWC during the SLAM. It's your cheapest chlorine (because you already own it). It must be turned off at the end when you do the OCLT.
    As far as I know, normal SLAM, and after you meet all three criteria, then 24 hours at mustard algae shock level, with extra attention to pool toys or anything that is in the pool.
    Pool School - Defeating Algae
    Pool School - SLAM - Shock Level And Maintain
    Pool School - Mustard Algae
    Be sure to get pH down to 7.2 before starting the SLAM.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    I have a total of 14 gallons on bleach with half being 8% and the other half at 12.5%. Plan on buying 4 more this evening on way home from work.
    Jul 2012
    Tallahassee, FL
    30,390
    Re: Ready to SLAM!
    That will be a good start. Must make sure to change the % in pool math when you fill in the values to find out how much bleach to add each time.
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Got it. Thank you
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Numbers before SLAM:
    PH-7.7 (lowering to 7.2)
    CYA-70
    TA-100
    FC-13
    CC-0
    Wish me luck! Will post on how things go then
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Also, not that it really matters but the bleach I have is 6gal@10% and 8gal@12.5%
    Jul 2012
    Tallahassee, FL
    30,390
    Re: Ready to SLAM!
    It will be good to know for the others that will follow your thread in the future and see how good you clear it!
    OH and you NEED to take picture of your pool looking down at your steps each day and share then here. That will help you and us see the color changes so we can judge how things are going.
    Leave your pump on 24/7 for the SLAM.
    Jun 2016
    Mechanicsburg, PA
    66
    Ready to SLAM!
    Not sure how good pictures would work. Tried taking some before but they did not turn out very good. Could not really see anything. I do have steps but had to remove them to get at any algae underneath. And there was a good bit of it under there. Should have taken a pic of that cause it was pretty noticeable. Sorry ☹️, if anything appears tomorrow (since I just brushed it all away) I will post.
    needsajet's Avatar
    Jan 2016
    4,224
    Re: Ready to SLAM!
    Way to go on the stairs!
    Kill that algae. Kill it real good. PoolMath for 28 ppm FC. Imagine a billion cells of slime getting knocked off by each jug.
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Update:
    July 29th@8pm
    Got FC to 28ppm
    July 30th@1230am
    FC-26 (bumped back up to 28 using pool math)
    530am-FC -28 was a bit confused until......
    930am
    FC-19! (Bumped back up to 28 using pool math)
    So that tells me something is dying
    Will post more as day wears on. Supposed to be somewhat cloudy today so hopefully sun won't be much of a factor. Shallow end of pool looking much better then before but deep end I am still seeing the stuff around the seams. Also brushed pool good before bringing up from 19 to 28.
    Jul 2012
    Tallahassee, FL
    30,390
    Re: Ready to SLAM!
    I am glad you are seeing progress. That is what the pics are for. Many times someone will say "my pool is not clearing up" BUT if they take and share pics daily then they can see the progress.
    You are on the right track! Keep up the great work!
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    Hard to take pics today. Been raining off and on all day. Just checked FC@4:00pm and it was holding at 28 but algae was still visible in seams so I brushed again.
    Jul 2012
    Tallahassee, FL
    30,390
    Re: Ready to SLAM!
    The clouds are helping your FC stay in the pool to kill the algae. NICE! Keep brushing and maybe think about vacuuming the dead stuff up instead of brushing it. That might speed things up.
    What kind of filter do you have? You have everything else in your siggy-THANKS!
  20. Back To Top    #20
    Jun 2016
    Mechanicsburg, PA
    66
    Re: Ready to SLAM!
    DE filter. Haven't really seen anything dead yet unless I am missing it. Only was brushing cause of the algae was reappearing in the seams. Not as bad but still there.
