- May 22, 2013
- 2,796
- Plaster
- Hayward Aqua Rite (T-15)
Usually they get the FC and the pH correct, but I'd rarely trust them on CYA. I've had mine jump 40 ppm from one day to the next and none had been added, nor any major water addition in weeks. It's almost like they throw a dart or just guess. That was one of the reasons I ended up here. Wanted to get away from granular chlorine and the 25 to 50 dollar bottle of "try this" when I'd have a problem.
Being you are in Florida I suspect you'd like a CYA of 40 and I like to keep my pools pH on the low side at around 7.2-7.4 You are in the acceptable range (7.2-7.8) just at the top of it.
Until your kit arrives there is no hurry in adding any stabilizer or acid. Do you have any stabilizer (CYA) or muratic acid (pH Down) on hand ??
If you know your pools volume can you please add that to your signature. I'm guessing you're around 13K gallons ?? If you're going to be using regular bleach from Walmart or ... it's usually around 6% and 1/2 gallon should be good. If you get liquid pool shock at walmart, big box store, pool store, ... it might be 10 to 12% and then you'd want to use less. Just make sure you stay away from anything scented or labeled splashless. They have stuff that will cause problems with your water like foaming.
Because bleach comes in different sizes and in different strengths this handy calculator will help you find the price per oz of bleach. It's a way to accurately figure out if a 6% 96oz bottle for X dollars is a better or worse deal than the 12% 128oz jug for Y dollars. Chlorine Price Per Ounce Calculator
It's an accurate way to compare an apple to an orange
