Thread: Plumbing connection to filter cracked and spraying water
    HouTX's Avatar
    Apr 2015
    Katy, TX
    49
    Is this union threaded or glued? Do I need to cut the pipe and install the new fitting or is it screwed on? Friends coming tomorrow to get in the pool thumb.jpg
    30k Gal, IG, PebbleTec, Jandy: CL460 Cartridge Filter, SHPM2.0 Pump (Filter+Spa), SHPM1.5 (Waterfall), spill-over SPA, PLC1400 SWG, LXi400 Heater. Polaris Caretaker Infloor Cleaning system, Jandy PDA-PS-8 remote, Taylor K-2006 Test kit
    Apr 2015
    tucson, arizona
    1,139
    Re: Plumbing connection to filter cracked and spraying water
    The union nut is threaded. But to remove you need to cut pvc pipe, replace the union nut and reglue the pvc
    HouTX's Avatar
    Apr 2015
    Katy, TX
    49
    Thanks, is this part vendor specific (Jandy) or is it universal that I can buy anywhere? Also, can I use the sheer descent which bypasses the filter and uses a separate pump, to keep the water circulating in the meantime?
    Apr 2015
    tucson, arizona
    1,139
    Apr 2015
    tucson, arizona
    1,139
    MagicMend® Insider Connectors - Magic Plastics Might help making connection in PVC easier
