Results 1 to 7 of 7
Thread: Solar cover
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Solar cover
    I started putting a solar cover on at night, I wanted to know if it is ok to run the filter while the cover is on?
    15,000 gal 16x32 above ground, aqua pro 2 hp cartridge filter, Hayward skimmer
    KazzyK810's Avatar
    Jul 2016
    Davison, Michigan
    75
    Re: Solar cover
    Yes! I started using a solar cover a few weeks ago. It has made such a difference to the warm of my pool, and I don't loose hardly any water overnight due to evaporation anymore. win, win!
    Karan - 18 ft round x 48" high - Intex ultra-frame AGP, Intex 3/4 hp pump with 14" sand filter (SF70110), Hayward 900 Wanda the Whale cleaner, Intex LED water fountain.
    18ft Round Intex Ultra Frame in The Mitten
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    Re: Solar cover
    I do it every night.
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Solar cover
    Ok good to know, cause that's when I put the chlorine in and run it over night
    May 2012
    Montville NJ
    545
    Re: Solar cover
    Mine rarely comes off the pool, unless we are using it. Depending on schedules and weather, it may stay on for 2 or 3 cycles of the pump. Never had a problem with it.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: Solar cover
    If it's warm and you leave it covered and not circulating during the day, be a little more alert for algae.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Russo221's Avatar
    Jun 2016
    Parlin , new Jersey
    133
    Re: Solar cover
    I actually haven't been putting it on the last couple days it has been too hot outside to put it on the pool water is already warm is it is
