Thread: Is a permit usually required for the plastering/replacing tile and coping?
    Jun 2016
    Boston burbs, MA
    45
    I know it depends, but generally speaking, if you aren't making changes to the pool itself... other than refinishing... is a permit required?
    Rhonda, Outside of Boston, MA
    20k gallon IG gunite circa 1984, very old/stained/worn out plaster finish
    4820 Hayward DE filter, no idea on the pump... will figure that out!, T-100 test kit, Speed Stir is the BOMB!
    *Researching options to refinish Spring 2017!*
    Feb 2016
    Atlanta, GA
    145
    Re: Is a permit usually required for the plastering/replacing tile and coping?
    I don't see why.
    MNiels's Avatar
    Mar 2016
    Seminole County, Central Florida
    17
    Here in Central Florida, our county (Seminole) requires a permit for refinishing/replastering a pool. It's a new requirement, just since January this year, so they can inspect to ensure that older pools are updated with anti-entrapment type covers on the main drain.
    Vintage pool, 1967. Inground, 23k gal, 38'x18', 3.5'-8' deep, no frills, screen-enclosed. Refurbished 2016: Pentair CC150 cartridge filter, WetEdge PearlMatrix Pebble; porcelain waterline tile; Hayward skimmer SP1070. Pentair/Sta-rite SuperMax VS 1.5 HP pump (6/2017). City water, no restrictions. TFPC, chlorine bleach, TF100, SpeedStir.
    Apr 2013
    Sacramento, CA
    2,769
    You are going to find this varies a great deal all over the country. The more urban the state the greater the permit requirements. Even then some only require permits for property tax tracking.
    Jun 2016
    Boston burbs, MA
    45
    Ok, good to know. Will add it to my questions when I am calling for quotes. Thank you!
