Thread: Spa temperature problem
    Jul 2014
    Raleigh, NC
    59
    I have the iaqualink controller for my pool spa combo and my spa temperature reads 86 degrees all the time. It never changes. Could the temperature sensor be bad?
    32,000 gallon inground plaster pool/spa combo spillover. Aqua Rite Pro with Sense and Dispense. Jandy iAquaLink Control. Polaris 280 vac. Sheer Descent, Fiber optic deck jet water feature. Vanishing wall. Whisperflo pumps, Pentair clean and clear cartridge filters.
    Apr 2015
    tucson, arizona
    1,121
    Re: Spa temperature problem
    The pool and spa temps should be close to the same until you activate the spa only. The temps should rise to what you set the spa for. Did you check pool/spa with a good thermometer to see where your temps are.
    Jul 2014
    Raleigh, NC
    59
    Yes. When the heater turns on the temperature goes up to 100 degrees but the automation system still shows 86. The temperature on the heater shows 100 but the iaqualink app shows 86 and it never changes.
