Thread: Salt level calibration
    Jun 2016
    Owasso/Oklahoma
    9
    Is there a way to calibrate my salt level readings on my Zodiac APUREM system? One day it reads 3.1 and the next day reads 3.5.
    20,000 gallon gunite
    Aquapure, APUREM
    Jandy PureLink Apure1400
    Jandy Stealth pump
    Jan 2012
    340
    Re: Salt level calibration
    That is not an option on that system.
    I would not worry about it. Both numbers are in range and close to one another in the scheme of things.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yep, if the SWG IS happy and making chlorine then life is good.
    Jun 2016
    Owasso/Oklahoma
    9
    Thanks guys.
    Aquapure, APUREM
    Jandy Stealth pump
