Thread: Deck Jet Material??
    Gags80's Avatar
    Jun 2016
    Stow
    10
    Deck Jet Material??
    Want to have this material around my deck jets replaced however i'm not sure what it is? Any ideas?
    For whatever reason it deteriorated since last year.
    Thanks
    Jay
    Gags80's Avatar
    Jun 2016
    Stow
    10
    Re: Deck Jet Material??
    Anyone have any ideas>
    SWG 31K Gallon 20X41 Vinyl Inground Pool
    Hayward S244T Sand Filter with AquaComfort Heat Pump ACT-1500
    Jan 2012
    340
    Grout? Hydraulic cement?
    Wouldn't put anything too wild in there in case you have to get the lid off the deck jet to replace/service the nozzle.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Feb 2015
    Chandler AZ
    938
    I'm making the assumption that the outer ring/cover stays in place during jet operation. If that's not true, disregard.....
    • Carefully dig out all the old material
    • Insert a thin Styrofoam backer rod to fill in the void - placed about 1/4" below the top surface
    • Caulk with a good quality elastomeric or polyurethane caulk
    This should allow future removal if needed and also provide a water resistant seal between the concrete deck and the deck jet.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
