Results 1 to 11 of 11
Thread: Chlorine level dropped to nothing in 2 days
    Jun 2015
    Michigan
    13
    Wth my Intex 18x48 2 days ago my chlorine level was perfect, today I tested and it was really low to the point of not registereing on my test kit. Will a clear solar cover cause this to lower that quickly ???? My PH is fine.
    Mar 2016
    Chicago,IL
    88
    Re: Chlorine level dropped to nothing in 2 days
    Chlorine loss is normal daily. A cover will actually help not lose as much. Do you have stabilizer in the water?
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Jun 2015
    Michigan
    13
    No stabilizer yet. Thinking about adding some bleach to bump it up. What do ya think.
    Also been running my filter for 6 hours a night and my SWG for 4
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    With no stabiliser your chlorine will not last long- you need to get stabiliser in ASAP. What test kit are you using?
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Jun 2015
    Michigan
    13
    Stabilizer a must have, as for the the test kit it's just a cheap one not anything fancy. I always thought that if you had a SWG you didn't need all the extra stuff
    I'm going to put my system in boost mode and see I if I can get the chlorine back up
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Quote Originally Posted by andycam View Post
    - - - Updated - - -I'm going to put my system in boost mode and see I if I can get the chlorine back up
    Welcome to TFP
    Actually with a SWG you'd want to keep stabilizer (CYA) a little higher than with a non SWG pool as the CYA is sort of sunscreen for the chlorine and the SWG generates chlorine slowly.
    It also helps us if you update your signature with your pool info
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jezza's Avatar
    Jan 2015
    880
    There is a lot of extra stuff that pool stores promote that we don't recommend as they are either unecessary or create further problems- needless to say they are also usually expensive. But there are still some things that are needed chlorine, stabiliser and acid are usually the 3 staples.
    You might want to consider ordering one of the recommended test kits while it might seem a little expensive to start with it will save you heaps in the end and keep you out of the pool store.
    Also have a read of this Pool School- Recommended Chemicals
    K-2006
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Jun 2015
    Michigan
    13
    Thanks all, looks like I got some learning to do yet
    Intex 18x48 - Intex sand filter - Intex SWG
    May 2013
    Richland,Michigan
    32
    andy I live in Michigan also and every spring I add stabilizer when I open the pool for summer.
    Otherwise the chlorine just disappears. I used hth stabilizer from walmart $8. 24 hours later numbers are spot on.
    30x18 Gunite inground pool with fiberglas side walls, 20k gallons, Sta Rite Sand filter .75hp pump
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Read up, then ask about anything you're not sure of. It's better to ask before putting something in you're not sure about. Do you know how to use http://www.troublefreepool.com/calc.html ?
