Thread: Poured concrete pool
    I recently had a poured concrete 36 x 22 pool installed. I don't read about any other poured concrete pools. It seems like all the residential pools are Gunite. Anyone know why?
    Viking Pool - Ceramic Fiberglass - Key West Sapphire Blue - 9,000 gallons
    Aqua Rite Goldline SWG
    Sta-Rite PXC150 Cartridge Filter
    Sta-Rite MPRA6F-148L 1.5 hp Pump
    30,427
    Re: Poured concrete pool
    Because so many pools are freeform, building traditional forms for a concrete pool is impossible in many, many cases.
    Free form shapes are extremely popular these days and are very easy to do with gunite. Builders like to stick with what they know, so they use gunite for everything, even if forms would work on a particular pool.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Gunite, shotcrete, formed pour concrete, just different ways to do the same thing - you end up with a concrete pool and need to follow the recommended chemical levels for 'crete' pools (as opposed to fiberglass or liner pools). There are subtle differences between the three in terms of concrete strength, but it's basically negligible (read: "marketing hype") 8)
    Dave and Jason gave you the reason mot crete pools are 'shot' The only other advantage in shooting a pool is that you get a monolithic pour - but I've never seen a poured pool leak or break at the cold joint between the floor and the walls
    BTW, you aren't the only one with a poured pool, the first pool company I worked for poured all their pools, supposedly they were strong enough to be the foundation for a 10 story building
    Luv& Luk
    -Ted
    We just started our poured concrete pool.
    It would be nice to see pictures of your construction and completed pool?
    M.
    25x25x16 L shaped concrete, 4' to 6', 21,000 gal, PLP4 - Pro Logic System Control & Aqua Logic Salt Chlorine Cell, Hayward TriStar 1 HP, 24" Sand Filter, SunHeater Solar Heating System, ColorLogic Light, Jandy deck jets.
    http://www1.snapfish.com/thumbnailshare ... _94788870/
    Just a few pictures of our build.
    Randy
