Thread: Conflicting Numbers
    Mar 2016
    Tampa, Florida
    93
    Conflicting Numbers
    Probably not a big deal in the grand scheme of things, but since I happened upon it after trying to figure out my target range for FC with my SWG pool, it seems the FC recommendation on these two pages is different:
    Gallons 13,860 / IG Pebble / Hayward OmniLogic / Hayward Swim Clear Filter / Hayward EcoStar / Hayward TriStar VS (for water features) / Hayward HeatPro Heat Pump / Date of build 3/11/16 / Other features: Spa / Hayward Colorlogic LED lights (2 in pool / 1 in spa) / Pentair LED Bubblers (2 one on each sun shelf) / Pentair Color Cascade Laminars (4 around pool) / Taylor K-2006 Test Kit
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Conflicting Numbers
    This has been brought to the forum's attention before.
    Go with the top one. Meaning 4 -6 The CYA chart states 4 - 6 for a CYA of 80. 3 - 5 for 70.
    CYA readings are very "range-ish" and a somewhat subjective test. Better to err on the high side. If you have a CYA of 70, a 6ppm FC sin't going to hurt anything.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Thanks. I'll work on that. I would say that the FC/CYA Chart is the go to authority.
    Mar 2016
    Tampa, Florida
    93
    Conflicting Numbers
    Quote Originally Posted by pooldv View Post
    Sorry, can you clarify this ^
    Edit - nevermind, I now realize that was a link. The link didn't show up in the Tapatalk app I was using. Sorry.
