Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: What do you to maintain correct levels?
    Jun 2016
    BLISSFIELD, MI.
    23
    Hello all, my first post of many....have lots of questions! I have a 33' round that is 52" deep with a 4' shelf all the way around that tapers to 6'2" in the center. It has a center drain along with skimmer and 2 returns. I have a sand filter and Frogger. This is my 8th season and I hate dealing with this pool, at least trying to clear it up! The last 3 years have been really good, nice and clear so very little maintenance. Well this year my winter cover was ripped to shreds and opened my pool with black water (last 3 years were crystal clear and maintained that all summers). So the pool has been open for a month, I have the bottom super clean (looked with goggles while at bottom) and the water is nice and blue but cloudy and wont take clorine. I have read through a few threads so I won't waste any of you time right now till I get the test kit on my water issue.
    The question I want to throw out there is about my Frogger system....is it good? Is there something better/cheaper? Would you recommend switching to salt?
    I can't believe it took me so long to finally get on the computer and find this site. My neighbor has a pool service business which he set me up with what I have but is just a total PITA to deal with so I am finally going to take ownership of this pool and get it where it needs to be!
    Thanks in advance, Shane
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: What do you to maintain correct levels?
    Welcome to TFP
    We have found the pool frog system to be one of the worst things you can add or use in your pool, it has metals and minerals, usually copper, while ok for killing algae it can turn your pool green, your walls black, your hair green and not keep your pool safe and clean and you still have to use chlorine..
    if you can shut it off and take the cartridge out it will help from getting more metals in your pool..
    at about 32000 gallons, you can pour 1 gallon of regular unscented not splashless bleach in a day until your test kit arrives
    I hope this helps
    Jun 2016
    BLISSFIELD, MI.
    23
    Quote Originally Posted by cowboycasey View Post
    Welcome to TFP
    I hope this helps
    Helps a lot, thanks! Prices are all over the place, what brand do you recommend and where do you get it? Once I get this pool stable how do you determine what and how much stuff to put in....do you just go off of what the readings are?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yes, do a little reading in Pool School.
    Start here, ABCs of Pool Water Chemistry
    And here, Pool School - Getting Started
    May 2016
    Troy IL
    476
    The Pool Frog system luckily does not use copper. At least not the one from King Technologies, the one I have/had on my pool. It uses silver and limestone. But still, I wouldn't use it.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Jun 2016
    Rolla, MO
    28
    They recommend getting a TF100 test kit on here and it is totally worth it. The instructions for testing your water are straight forward and you can get accurate results immediately. Use the links they provide for information about taking care of your pool because you should only need a handful of products to maintain your pool like bleach, baking soda, muriatic acid etc.
    Above ground 24 ft diameter
    Sand Filter
    TF 100 Test Kit
    Feb 2015
    Chandler AZ
    926
    TFTestkits.net
    This is the one I use and highly recommend. It's the best bang for the buck as it contains more reagents for testing tests you do most often.
    If you can swing it, get the a Speedstir too. Well worth it and makes your testing easier and much more accurate.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jun 2016
    BLISSFIELD, MI.
    23
    Just ordered the TF100 and the speedstir. What brand and place do you buy the bleach/chlorine? Here's another issue...going on vacation tomorrow for the next 5 days.....with my pool a mess and not getting the kit in time to test water before I leave, what do you recommend I do to try and keep it from turning green while I'm gone?
    Thanks for replies!
    DFW, TX
    24,485
    Add your pool info to your signature so we can quickly find it and answer questions like this one. More here on what to put in your signature and how to do it, Pool School - Read This Before You Post
    I buy bleach at the grocery store, concentrated, unscented store brand. I buy muriatic acid at lowes. Raise your chlorine level to 10 ppm and hope for the best. Use Poolmath to calculate how much bleach to add. The link to Poolmatch is up there ^^^.
    Jun 2016
    BLISSFIELD, MI.
    23
    Quote Originally Posted by pooldv View Post
    I put the sig info so I'll se if it works?
    33' above ground.. 32,000 Gal. Hayward Model S220T Sand filter, Hayward Power Flo LX pump 60gpm, Deleted Frogger (Thanks TFP)
    Feb 2015
    Chandler AZ
    926
    Signature shows fine.
    Could you please go back in and edit to include filter model, pump model/HP, type of testkit, cleaner and any other info you have on pool equipment. This will make it much easier to see what you have and help us to better tailor anyou suggestions to your specific equipment.
    You're going to love the TF100 and Speedstir! Great job getting it ordered!!
    Gene
    DFW, TX
    24,485
    More here on what to put in your sig, Pool School - Read This Before You Post
    Casey's Avatar
    SW PA
    10,435
    If you're leaving for vacation tomorrow, don't worry about the pool. You more than likely need to SLAM the pool as it is so just go. We'll set you straight when you get back.
    Jun 2016
    BLISSFIELD, MI.
    23
    Thanks all, I'll get my sig straightened out and report back when I get some numbers! Looking forward to a clear pool without the pool store stuff. I think I am around $300 deep and still have a cloudy pool after a month!
    Aug 2014
    Northern IL
    4,615
    We can fix that! No frog....!
    And use this to shop for chlorine but ignore the zip code search as it is not updated regularly:
    Chlorine Price Per Ounce Calculator
    DFW, TX
    24,485
    Right! We call that being Pool $tored!
    Jun 2016
    BLISSFIELD, MI.
    23
    Ok, I'm getting ready to leave and I pulled the frog bac pac out and filled it with large chlorine tablets. Just trying not to come home to a green pool??? Cant wait to come home to my new test kit!
    Jun 2016
    BLISSFIELD, MI.
    23
    Ok, finally back from vaca and went right out and did my tests and here are the results:
    FC .5
    CC .5
    CH 350
    TA 170
    CYA Less than 20ppm???? filled to top and could still see black dot.
    Also updated sig with filter and pump info. NOTE: this is my 8th season and my filter has never had the top off it. Should I take it off and clean the top of the sand? (I watched that vid on cleaning sand filters)
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    If you filter hadn't been deep cleaned in 8 years I'd say you're overdue. I added that to my yearly startup procedure this year.
    Add enough CYA to go to 20. You might have some already from the vacation tabs. Get a little more chlorine in today, around 3. Once the CYA is dissolved, use the chart.
    How does the water look?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
  20. Back To Top    #20
    Jun 2015
    N Tonawanda, NY
    469
    We also need to know your PH.
    It's one of the 1st things to adjust.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
