Results 1 to 13 of 13
Thread: Friends pool next door
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    FC-43.5
    Cc-0
    Ph-6.5
    TA- will not read
    Cya -140
    Ch-not tested vinyl pool
    26000 IGP
    Pool water is green
    I think I need to start with the PH yes or no
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Friends pool next door
    Yes, that's very low. Looks like a drain is needed too.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    What PAGirl said. How is the FC 43? Already start a SLAM? Ph should have been adjusted first for future reference.
    30,421
    You don't say how big the pool is, but a 50% drain would appear to be your first step.
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    The neighbors pool is 26000 gallons
    Inground liner pool
    30,421
    I would drain half the pool and refill. It will solve the VERY high CYA problem and probably get the pH closer to 7.2 - 7.8
    How did you measure 6.5 pH
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    With the T-1000 Taylor test kit. With blue kit 6.8 sorry that was fat fingered sorry
    Oct 2010
    michigan
    284
    Rolo where in macomb are you? Also from macomb
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    By Partridge Creek Mall
    Oct 2010
    michigan
    284
    Hello neighbor, i,m 5-8 minutes away.
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Ok I'm draining now
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Here are some new numbers after I drain the pool about 50%
    Fc-26.5
    Ph7.2
    Cc-0
    Tc-26.5
    TA-110
    Cya-100
    My next move anyone ??
    Jun 2012
    Butler, PA
    336
    If you have added water, you will need to do another 50% drain.
    *if they have a SWG ~ you would want to be in the 70's or 80's I think for CYA. You didn't mention that. If there is no system you will want that CYA lower to be manageable, especially knowing you need to SLAM it.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
