Page 1 of 4 1234 LastLast
Results 1 to 20 of 70
Thread: Cloudy Water
    Jun 2016
    Farmingdale, nj
    40
    Cloudy Water
    Hey all! New to the forum but I am having issues with cloudy pool water. I had an algae bloom Tuesday this week which I vacuumed up and shocked the pool. After shocking the pool went cloudy and hasn't returned to clear yet. It isn't horrible and I can see the bottom and all around but it isn't clear. We added clarifier too and it didn't help.
    I had the water testes at the pool store to see if it matches my tests and it did so I'm at a loss. The store recommended not adding anything and just keep letting the water filter.
    The pool I have is a 22x52 Intex metal frame with the supplied filter. The water was crystal clear just before the algae bloom and I did cut the filter rum time to 6 hours just before the bloom to try and save electricity. Below are the water results.
    Free chlorine 5.4
    Total chlorine 5.4
    Combined chlorine 0
    Ph 7.4
    Hardness 71ppm
    Alkalinity 71ppm
    Cya 23ppm
    Copper .1ppm
    Iron. 1ppm
    Phosphate 964ppb
    I'm still going to swim since everything looks good but I want a crystal clear pool again.
    The store suggested maybe when I shocked it I added too much chlorine. It stayed above 10ppm for a few days and is just now dropping. It hasn't been too sunny this past week but is supposed to be today and tomorrow.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cloudy Water
    Too much chlorine will not cause cloudiness. Not enough will cause cloudiness as that's a sign of algae starting to grow in the pool.
    The best way to take control of your pool is to get a test kit we recommend here and stay away from pool store testing. Home test kits are more accurate and much more convenient. Check out Pool School - Test Kits Compared The TF-100 from tftestkits.net is your best value and the Taylor K-2006 is good as well, just has less reagents that you need, specifically when needing to test frequently when dealing with algae.
    Check out ABCs of Pool Water Chemistry to get a feel for our methods here. We use a process called SLAM here to deal with algae. It works every time when performed diligently with a recommended test kit. After you check out the ABCs, you can move onto the SLAM procedure and Chlorine/CYA chart in my signature.
    1. Get a test kit ordered
    2. Do some reading so you are prepared to take control of your pool.
    3. Ask more questions as needed!
    Isolated Spa - 345 Gallons
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    Unfortunately I'm broke at the moment waiting for some $ to come in. I'd there anything I can do now based off of the tests done already until I can get some $ together?
    Intex 22x52 AG, 12,000ish, Krystal Clear Cartridge Filter 2,500gph, K-2005 test w/ FAS-DPD soon to be on order, Chlorine
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    Also I have chlorine in the pool so it's not that there isn't any..
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    Ok so my local Lesli Pools both has and uses the Taylor kits. I was able to get one of the ones they had there and they tested the levels for me as well..
    Free Chlorine 3
    Total Chlorine 3
    Calcium Hardness 0ppm
    Cyanuric Acid 40ppm
    Total Alkalinity 100ppm
    PH 7.4
    Copper 0
    Iron 0
    TDS 800
    Phosphates 300ppb
    Temp 75
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    Also they weren't happy about the HTH walmart clarifier either so I bought some of theirs and will try tomorrow
    38,260
    Re: Cloudy Water
    Stop wasting money on clarifier and potions ... Did your test have the FAS-DPD chlorine test with powder? If not, it is the wrong kit.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Cloudy Water
    HI Danielle
    Nobody here would reccomend you purchase clarifier. It isn't necessary. I think you need to decide if you want to spend money on a good test kit that includes a fas-dpd chlorine test as well as everything else you'll need to test or if you want to spend your money on what the pool store tells you to. Our advice doesn't mix well with theirs but we have no skin in the game when it comes to chemical sales like Leslie's does.
    Most of us understand being on a budget but have learned that over time with proper testing we spend far less than a pool store would have you spend.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    It's a DPD test but I see no powder
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    K-1004 DPD test kit is what I have
    38,260
    Re: Cloudy Water
    Wrong kit. I think that is missing a lot of the needed tests, especially the FAS-DPD which is not! The same as the DPD test.
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    Ok maybe tomorrow I can exchange it bc I can't go back today..in the meantime..are the results I posted helpful at all...two different kinds of tests were done on the water today
    38,260
    Re: Cloudy Water
    You need to follow the SLAM process which requires a higher FC level than you can test for.
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    Also is the K2005 a better kit? They are limited to what is in the store
    38,260
    Re: Cloudy Water
    Better, but still missing the FAS-DPD chlorine test which is required.
    38,260
    Re: Cloudy Water
    There is an article in Pool School during the only approved test kits ... Get out of tapatalk
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Cloudy Water
    Check out this link Danielle, previously posted in post #2 of this thread. Pool School - Test Kits Compared
    What we here on this forum aim to do is help educate you to take control of your own pool and therefore NOT spend extra money on unnessary things the pool store wants to sell you. You likely will not find a test kit that includes the fas-dpd chlorine test retail locally. There is a reason pool stores don't sell the quality test kits and test your water for free......because they then can sell you things like clarifier that you don't need to spend money on.
    Please review the links in post number two of this thread as well as more articles in pool school if you want to help yourself then post questions. If not, you can keep following Leslie's advice.
    Jun 2016
    Farmingdale, nj
    40
    Re: Cloudy Water
    It's not that I want to follow the stores advice but I'd rather not wait for shipping and be able to pick things up immediately. I'm going to return/exchange the kit. The guy thinks they have a fas/dpd kit if not idk. I don't even think I took the receipt from the store so getting a full refund may be a problem. I also don't want the water to just sit like this until I can get a kit..is that what I should do just let it sit and wait days? Won't it be worse?
    I'm just frustrated and at a loss.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Cloudy Water
    Add your pool info to your signature and we can recommend a daily dose of bleach. Brushing and scooping also helps. It only takes a few days to get the right test kit fro TFTestkits.net.
    More here on what to put i your signature and how to add it. Pool School - Read This Before You Post
  20. Back To Top    #20
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Cloudy Water
    Quote Originally Posted by Danielle1 View Post
    I can feel your frustration. I hope you've done some of the suggested reading in pool school. Without the fas-dpd chlorine test, you can't accurately follow SLAM. You can in the mean time add about 1/2 gallon of regular bleach a day and brush a lot.
    I know the desire for instant results but what we teach is a concept of testing and understanding what your pool needs. My advice is the bleach (half gallon or so daily) only if your ordering a good test kit and get that kit and then post up test results. It will provide you years of pleasure knowing your own pool with your own test results.......not tomorrow of course but long term.
