Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 113
Thread: N/B IG pool/spa/grotto/waterfall/slide start 7/26
    Apr 2016
    fontana, CA
    92
    I'm hoping to start the dig on July 1st, just waiting on funding. It's going to be about 32x20. Still waiting on the other plans.
    I have questions on equipment, for now. he quoted me $8700 on equipment, but said I can buy it on my own if I want. His price includes: 400,000 BTU heater, pentair variable speed pump, pentair 3/4 pump(slide/waterfall), DE filter (70 system), 2LED lights (pool/spa), Pentair IC 40, Intermatic timer switch ( no idea what this is), 3 actuators (IDK), 2 backflows, and I can add the system logic easy touch with salt cell for $1200.
    I was really thinking that I should get 3 pumps, but don't know if that's overkill.
    Don't know much about easy touch or intellitouch, but no that I want automation for my lights, waterfall, spa, etc. If I go this route I'm assuming I have to order special valves.
    Thanks in Advance for your wealth of knowledge.
    Fontana, CA, started 7/26 completed 8/31, IG pool/spa/slide/waterfall/grotto 17,000 gallons, pentair quad 100, pentair mastertemp 400,000 BTU, Intelliflo VS 3HP, Easytouch 8 w/ IC40, screenlogic 2, 2 5g color LED pool lights, 5g color LED spa light, TF-100
    May 2015
    Land O Lakes, FL
    527
    Re: New build starting July 1st
    How many gallons will the pool be?
    I would probably go with the EasyTouch 8 and SWG package. Size is the question and why I asked how many gallons.
    Actuators are required to automate the movement of the valves that turn features on and off. For example, if you want to click a button to turn on the spa, the Easytouch will activate a actuator to change the flow to the spa.
    I used these actuators. You can buy 2 or 3 for the price of one pentair.
    Amazon.com: Intermatic PE24VA 24-Volt Pool/Spa Water Valve Actuator: Patio, Lawn Garden
    An example (may not be the correct model) of the Easytouch with SWG package.
    Pentair 520545 EasyTouch 8 Function Control Pool/Spa Combo with IC40
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Very nice pool! The pricing sounds pretty typical to me but where are you located? We're getting two pumps, one for water features and a Pentair VSP. We're doing the SWG, EasyTouch 8, and Screen Logic for automation.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Apr 2016
    fontana, CA
    92
    Quote Originally Posted by twinkiesmommy2009 View Post
    I live in Southern California.
    What size pump for your water feature? I want to make sure that my slide has enough water pressure, along with the waterfall.
    Thanks!
    Apr 2016
    fontana, CA
    92
    Quote Originally Posted by mgmoore7 View Post
    Thanks so much for your help. I'm not sure how many gallons, but I'll try to get this information. I thought I wouldn't know until I started filling.
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    Beautiful design, you guys are going to love that pool!
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
    Aug 2015
    Cypress
    1,679
    The picture looks like they used a design program like Pool Studio. Your PB may be able to have the program give the gallons if you ask them.
    Here is what we did:
    Oh, it doesn't say there. We have 3 sheers, the spa, and 3 bubblers for water features.
    Apr 2016
    fontana, CA
    92
    Quote Originally Posted by bdrex28 View Post
    Thanks! I ordered a geek pro to make time lapse videos. We are so excited.
    Apr 2016
    fontana, CA
    92
    Thanks for the breakdown. I think I need the niche light for the sun shelf. I will ask my PB for that information. I am supposed to be getting the layout plans on Monday. I'll post once I get them.
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by bcampbell View Post
    Initially we wanted the LED bubblers for the shelf but due to condensation issues (and size) our PB talked us out of it and into the niche light. I think it's the right choice. Check out some of the other build threads around here. You'll get a ton of fabulous information, ideas, and it's fun reading and seeing the transformations from design to actual pool. Can't wait to see!
    Aug 2014
    Houston tx
    2,525
    Pentair has a pool volume calculator that can help you determine your gallons.
    Pool Volume Calculator | PENTAIR
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Apr 2016
    fontana, CA
    92
    Quote Originally Posted by Marlahoutex View Post
    Thanks Marla. Using that app, my pool should be around 20,000 gallons.
    Apr 2016
    fontana, CA
    92
    I've been seeing people are getting blowers in their equipment, what is that used for and is it something that I should be looking into?
    Aug 2015
    Cypress
    1,679
    The blower we're getting will be for the jets in our spa.
    Apr 2016
    fontana, CA
    92
    Is it because you're getting special jets? I'm also getting a spa.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,761
    A correctly designed spa does not need a blower, its an unnecessary expense.
    Slides require a surprisingly low amount of water flow. Why do you think you need 3 pumps? Go with a waterfall pump, 3" plumbing and use a diverter valve to control the flow to the slide. You could automate this to have the waterfall, slide or both running if you choose.
    The Easytouch 8 w/ IC60 (P/N 521150) is what I'd recommend. It comes with 2 valve actuators (Pool/Spa). You may need a couple more dependent on what you choose to automate. If you get an EasyTouch you need to include ScreenLogic2 (P/N 522104).
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Aug 2015
    Cypress
    1,679
    No special jets. I was told on here that a correctly designed spa does't need one too and I looked into it but my research with the actual builders in my area indicated that most must not know how to design them that way because all 15 I spoke to said I needed the blower. Since my husband will like plenty of pressure anyway, I let it be. Many builders seem to be old school and don't like change. It made better sense in this particular case to let them do what they know rather than having them learn differently on my pool.
    I think that 2 pumps should be plenty - as long as they are the right pumps.
    Apr 2016
    fontana, CA
    92
    Quote Originally Posted by bdavis466 View Post
    Thanks so much! I would like to cut out unnecessary things because there is always somewhere else to spend the extra money.
    Apr 2016
    fontana, CA
    92
    Again, thanks!
  20. Back To Top    #20
    Aug 2015
    Cypress
    1,679
    Did they start yet?
