Results 1 to 8 of 8
Thread: Caretaker Problems
    Jun 2016
    Sahuarita Arizona
    4
    Cool Caretaker Problems
    I have a Caretaker 99 5 port system with a few problems 1. Low pressure cone filter clean! 2. The cone filter needs to cleaned at least 2 times a day! My main filter is a 4 cartridge Hayward!
    Jun 2014
    15,221
    Re: Caretaker Problems
    Hello and welcome to TFP! I'm curious, so others may be as well... even though I don't have the Careteker floor system, I'm wondering if there is any chance algae could be contributing to your pressure problem. Do you have your own test kit by which to post some water test results? Perhaps another Caretaker owner will reply with some advice as well. We'll watch for updates and try to help any way we can. Nice to have you with us.
    http://www.jandy.com/~/media/zodiac/...tl/tl-1301.pdf
    How to Unclog a Caretaker 5-Port Valve or Caretaker 99 In-Floor Cleaning System - YouTube
    38,475
    Debris should not be able to reach the filter on the caretaker.
    Jun 2016
    Sahuarita Arizona
    4
    I get a lot of debris in that little cone filter it will take a garden hose to clean it out! I just wonder why? Chlorine 3/6, PH 7.5, Alkalinity 120, Hardness 300, Cyanuric Acid 40
    12000 gallon in ground w pebble tech finish - Kool Deck - All Hayward equipment - caretaker 99 system - Fountain Feature
    38,475
    Are you sure there is no damage inn your main pool filter?
    Jun 2016
    Sahuarita Arizona
    4
    I am going to take a look today! I will post my findings!
    Jun 2016
    Sahuarita Arizona
    4
    After inspection the filter I found that algae had the 4 cartridge filters plugged. A good cleaning and the system is happy including the Caretaker pop ups!
    Quote Originally Posted by mrmerc50 View Post
    38,475
    Algae will quickly do that.
    You should clean the filter when the pressure rises 20-25% over the clean pressure.
    Are you following the ShockLevelAndMAINTAIN Process to clean up the algae problem?
