Thread: New Pool Chemicals
    Jun 2016
    Warren, MI
    15
    New Pool Chemicals
    Hey all
    In anticipation of getting our pool installed next Friday (7/1) I ordered the K2006 kit off Amazon (had a gift card to burn). I have tested the water from my Tap so that I can go purchase needed chemicals to get the pool ready:
    Here are my numbers:
    PH 7.0
    FC 1.2
    TA 100
    CH 110
    I know I dont need to do CYA since its tap water, but do I need to perform the CC test?
    I plugged my number into PoolMath and got the following:
    FC 78oz of 6% Bleach
    PH 95oz weight of Borax
    TA 0
    CH 300oz weight of Calcium Chloride
    CYA 72oz weight Stabilizer
    Does this sound about right?
    Pool is about 13,500 Gallons
    Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New Pool Chemicals
    You will need stabilizer (CYA, cyanuric acid) for sure.
    You will need bleach. FC is a consumable and must constantly be replenished.
    Eventually, you will likely need muriatic acid to reduce pH. Your pH is a little low in the tap water, but shortly after filling and circulating your pH will likely rise due to aeration and your TA level. Wait to adjust pH after you have circulated the full pool for about an hour.
    If your pool is has a vinyl liner there is no reason to raise CH. As long as your CH is greater than 50 and less than 350, don't worry about CH at all.
    It's great to test your tap water for practice but test everything again once you fill your pool and have circulated. You can also ALWAYS use a 10 mL sample volume for the FAS-DPD test for FC/CC. 1 drop = 0.5 ppm. It saves on reagents and is precise enough for nearly all purposes of managing a pool.
    Isolated Spa - 345 Gallons
    Jun 2016
    Warren, MI
    15
    Thanks Joel
    I'll run to Walmart and see if I find some of that Chlorine for $2.50/gallon everyone talks about on here. I'll grab some CYA too.
    It is a vinyl liner, I just updated my signature to reflect the pool specs.
    24' Round Sharkline Harbortown - Pentair SD60 Sand Filter - Pentair Optiflo 1.5HP 2-Speed Pump - K2006 Test kit
    Mar 2015
    South Texas
    411
    Quote Originally Posted by mgk645 View Post
    Thanks Joel
    Unfortunately, I just got done reading that Walmart bumped it up to like $3+ a gallon. In that case, just buy Great Value Bleach. No splashless or scented. It's 8.25%
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Quote Originally Posted by nlindelldc View Post
    Just saw a large display of the $2.50 jugs at Walmart today. You can also use this calculator.
    Chlorine Price Per Ounce Calculator
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2015
    South Texas
    411
    Quote Originally Posted by AimeeH View Post
    This is good news. Hopefully that was an isolated incident
