Results 1 to 7 of 7
Thread: First time pool owner.
    Jun 2016
    Spencer, OH
    4
    Just filed up new pool with b water that we had hauled in. What next?
    Intex ultra frame 26' 52" deep. First time pool owner. Located in ohio.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: First time pool owner.
    Welcome to TFP!
    Do you have a test kit?
    Generally add chlorine to keep,things from growing, adjust pH and add CYA.
    Have you read ABCs of Pool Water Chemistry?
    Support the site
    38,251
    Welcome to TFP!!!
    Your CYA is 0, so you need to add 30ppm of stabilizer in a sock and get that dissolving.
    You also need to add chlorine, get around 2ppm of FC in using bleach.
    Use PoolMath to tell you how much of what to add.
    No idea about anything else because you did not post any test results You get one of the Recommended Test Kits yet?
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Also please add your state to your location in your profile.
    Jun 2016
    Spencer, OH
    4
    I haven't tested anything yet.
    Jun 2016
    Spencer, OH
    4
    I bought a little crappy test kit that only tests chlorine, bromine and ph levels.
    38,251
    Well, seems that you have to decide if you are going to maintain your pool to TFP standards ... if so, you need one of the recommended test kits.
    Have you added the CYA and FC yet? I certainly hope you have started added chlorine.
    Jun 2016
    Spencer, OH
    4
    I added the chlorine and cyanuric acid.
