Thread: Here's my test I want to drop the alkalinity down ???
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Fc - 10.5
    TC- .5
    Ph - 7.5
    aly- 120
    cya-80
    The water is clear and nice should I drop my alkalinity or not
    And if so should I use acid
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,531
    Re: Here's my test I want to drop the alkalinity down ???
    If the pH is stable at 7.5 or so, I would not screw with the TA at all. If pH raises above 7.8 then I'd use acid to lower both pH and TA and then aerate to bring the pH back up.
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    That's what I was thinking but I want to second opinion.
    Thank u
    jim
