Thread: IG Lighting
    Jun 2014
    Ponchatoula, LA
    2
    IG Lighting
    18x36 vinyl did not have lighting installed in pool when built. Is installing wiring/light canister a DIY project or professional only?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: IG Lighting
    It could be DIY if you're skilled in electrical, concrete and excavation work. If you're putting in a light niche, I'd recommend having it done professionally. There are some other options out there now such as fiber optic pool lighting that might be more DIY.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Jun 2014
    Ponchatoula, LA
    2
    Re: IG Lighting
    Thanks JVTrain. I just contacted my local pool builder who recently installed a liner and new pump for me. He is going to work up a quote on a couple of lights, which I'm sure will run me over $2k if I'm lucky. I will have to figure out whether or not my family will enjoy swimming enough at night to justify the cost.
    Anyone know of any alternative methods of lighting a pool without running canned lights?
    Feb 2014
    Central Minnesota
    5,080
    Re: IG Lighting
    If you check out this thread, a user has used LED strip lighting to add light to the pool. I believe this is technically against electrical code, but I'm not certain. Making an old pool NEW again If you didn't want to put it below the coping, you could do a similar LED strip in your fencing or other area around the pool to be up to code.
    There are also some fiber optics options that may be amenable to DIY, depending on your ability to work with FO cable and lighting. LED and Fiber Optic Lighting by Wiedamark - Fiber Optic Pool Spa
    It's easier to meet electrical code with FO lighting since there is no wiring near the pool, only the FO cable.
    Apr 2013
    Sacramento, CA
    2,769
    Re: IG Lighting
    Yeah the LED strings don't comply with the code.
    You may want to look at Nicheless lights. They install into 1 1/2 PVC and are now comparable with standard LED.
