Thread: Code 91
    Jun 2016
    Mobile ala
    1
    Code 91
    We have cleaned our cell and still get the code 91 low salt and service cell
    Jun 2011
    Long Beach, CA
    2,784
    Re: Code 91
    Welcome to TFP!
    We need more information such as the brand of SWG that you have.
    Please make a signature and list your pool specs as that will help us to help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Code 91
    Welcome to TFP!
    More here on adding your signature and what to put in it so that we can better help you with your pool. Pool School - Read This Before You Post
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Code 91
    A quick Google Search: "code 91 salt cell" tells me OP has an Intex 8110. The search turned up many suggestions. In a nut shell top of the list is:
    1. Scaling can give a false low salt reading, needs to be cleaned - You did this already so check.
    2. Cell could be going bad - How old is it?
    3. It's possible you really are low on salt. Have you done a manual test?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
