Thread: CYA beyond measure on tf 100 TEST
    Jul 2015
    HARRISBURG NC
    11
    CLORINE- 0
    PH-8.2
    Alk-400 +
    Stablizer no graduation above 100 just estimating is 400
    Water is clear with no algae
    25 year old construction
    20x40 In vinyl 36k gal
    2 skim 3 returns
    Pentair super flow VS, Sand Filter
    TF 100 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: CYA beyond measure on tf 100 TEST
    start by taking equal parts of pool water with tap water. Then use this to perform the cya test, but double the results. If it is still 100, use 1 part pool water to 2 parts tap water and triple the result.... get the idea? Not entirely accurate but close enough!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by roallen61 View Post
    CLORINE- 0
    PH-8.2
    Alk-400 +
    Believe it or not, that is one of the most common complaints on this forum. Not that the tester is no good, but high CYA. A steady diet of pucks and a weekly "shock" will rack up the CYA numbers in a big hurry.
    The workaround is a dilution test. You're looking at a partial drain and refill no matter what, but it's nice to know in advance how much you can expect to replace. You don't want to be one of those who posts "I replaced half my pool water and CYA is still over 100" To do it, fill the mixing bottle to the first line with pool water, then to the second line with tap water and mix. Then pour off half. Then repeat the CYA test using that diluted sample as the pool water and double the result.
    Alternately, go snitch a measuring cup from the kitchen and mix a sample using that and then pour some of that ble4nd into the mixing bottle. If you suspect the CYA is really over 200, then 2 parts tap water and 1 part pool water and triple the result.
    I'd also suggest you run the CH test, too. If it's astronomical, you'll feel better about draining that much water.
    Don't bother treating the water you have at the moment since you'll likely end up dumping a bunch anyway.
