Results 1 to 9 of 9
Thread: New test kit
    Jun 2016
    Water valley ms
    7
    New test kit
    I'm just using new kit tf100. My readings are. Cc-1
    Fc-2
    Tc-3
    Ch-300
    Ta-70. What should I add
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New test kit
    Welcome to TFP!!
    What are the following?
    pH
    CYA
    How does the pool/water look?
    Support the site
    Jun 2016
    Water valley ms
    7
    Re: New test kit
    Thanks for reply my ph was around 7.5 and have not do e cya yet well get done and posted
    Jun 2016
    Water valley ms
    7
    Re: New test kit
    Cya is 30
    38,284
    Re: New test kit
    Welcome to TFP!!!
    Have you done much reading of Pool School?
    What do you think needs to be added? We are here to teach people how to maintain their pools.
    How does the water look?
    You numbers certainly look better than many new members.
    Jun 2016
    Water valley ms
    7
    Re: New test kit
    Thanks water is cloudy
    I have not read a lot yet put plan too we have been tRying to clear water for w months per pool supply store
    Jul 2015
    Central Valley CA
    1,107
    Re: New test kit
    Those numbers look pretty good the CC might be a little bit of a concern and with cloudy water you might need to SLAM. Have you done any reading in Pool School the ABC's perhaps? How old is the pool and how has it been maintained till now.
    Can you fill out your signature with the details about your pool read THIS for an idea of what we are looking for it will speed things along a bit. To get to your signature there is a link in the "quick links" drop down menu at the top of this page under the Rules button.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    38,284
    Re: New test kit
    With cloudy water, and a significant CC number, you need to follow the ShockLevelAndMAINTAIN Process.
    Although I would suggest a little reading prior to you understand some of the chemistry:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jun 2016
    Water valley ms
    7
    Re: New test kit
    Thanks for all the replies
