Thread: Shock and swg
    Jun 2016
    sparta,nj
    1
    Shock and swg
    Is there a specific kind of shock to use with swg pools?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Shock and swg
    Welcome to the forum.
    The best type of shock in any pool is plain old bleach. It adds nothing to your pool but chlorine and a very small amount of salt.
    Check out our ABCs of Pool Water Chemistry article for more details on how we teach folks to manage all kinds of pools here on TFP.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Shock and swg
    Welcome!
    Just in case you weren't aware... if you maintain high enough FC for your CYA level, you won't get algae and may never have to "shock" your pool again.
    Weekly "shock" treatments are a pool store gimmick.
    If you have algae growing now, then what you need is a SLAM. It uses high chlorine levels like a "shock" but controlled and sustained long enough to do some good.
