Thread: When I replaced my motor I noticed the new one was a 2 hp
    Jun 2014
    Roseville, CA
    343
    I have water solar, and I notice it fills the panels faster, but am I using more electricity than before when everything is full and I'm on normal load?
    Thanks in advance...
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    38,235
    Re: When I replaced my motor I noticed the new one was a 2 hp
    Is there a question here?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Did you replace the whole pump or just the motor portion?
    If you just replaced the motor, you are probably not using more power. If you replaced the whole pump, you probably are using more.
    38,235
    Sorry, I reversed "Am I" to "I am" ....
    If you are moving more water, you are likely using more power.
    Jun 2014
    Roseville, CA
    343
    Got it.
    I'll have another thread for advice, asap.
    My Ideal Specs:
