Thread: Salty!
    May 2013
    Fort Lauderdale, FL
    34
    Salty!
    Hi everyone! I'd like to buy a test for salinity in my salty pool, something I can use seperate from the AquaPure's own meter.
    Is the Taylor K-1766 a good idea? Or something else?
    Thanks all!
    11,800 gallon diamond-brite in-ground pool with second-level 5 ft. diameter spa.
    Jandy DEV48 D.E. filter / Jandy AquaPure 700 SWG with AquaLink RS and PDA Controls
    Jandy Stealth SHMP 1.5 pump / Jandy EEiT EE2000T Solar/Electric Heater.
    TF-100 Test Kit with Taylor K-1766 Salt Test
    Pool is inside a screened enclosure in South Florida.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Salty!
    The K-1766 is good. Buying it from TFTestkits.net is even better.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    Re: Salty!
    Works for me. Just today, I had to prove to myself that it works on cold or heated water. Should have just trusted TFP. It was exactly the same at 60F and 90F. It's 200 PPM per drop, so with droplet variability I suppose it's +/- 10% and plenty of resolution for the job. The end point is easy to detect.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
