Thread: best add on water autofill device
    Jul 2012
    Whidbey Island, WA
    397
    What is "best" add on water autofill device?
    Had a Sentry and it stuck open and flooded. Is cheaply made.
    Recommendation for better add on water autofill device?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    38,488
    Re: best add on water autofill device
    Define add on?
    I added one to mine. Involved drilling a hole through the pool and plumbing in the bucket and float valve.
    Jul 2012
    Whidbey Island, WA
    397
    Define add on?
    thanks
    was thinking of device with no plumbing; like the Sentry; just attach to coping and connect hose
    38,488
    Ah. Adding a simple timer on a hose to add a little water each day might be more reliable.
    Jul 2012
    Whidbey Island, WA
    397
    true
    but what about this guy
    <http://www.amazon.com/dp/B018ESV4U4/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=O1A5KJWD8CXP&co liid=I2XZSXKL01Q69A>
    38,488
    I can not recommend a product I have never heard of or have any experience with
    If you decide to try it, please report back with your findings
