Results 1 to 10 of 10
Thread: How to paint aluminum coping
    I have a 9 year old in ground pool with white aluminum coping that is in need of painting. There are multiple areas of worn paint from the solid safety cover.
    Any advise, products, technique would be appreciated.
    Thanks
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Jun 2007
    New Jersey
    653
    Re: How to paint aluminum coping
    I would love to see a good answer. I have tried to paint unpainted outdoor aluminum furniture and to repaint white aluminum storm doors, all with unsatisfactory results. The only stuff I found that is made to paint aluminum is XO (they have an aluminum primer--then the usual XO topcoat). It works--but it seems to attract dirt that won't come off, and I have to repaint every year to keep it decent. Of course, you could send the pieces off to be powder coated. It might be cheaper than a new pool.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    KirstenHW's Avatar
    Hudson Valley, NY
    19
    4 years ago we replaced the liner on our 1981 Spartan inground. The aluminum coping was in need ot refinishing as well. Since the original liner was being pulled, we knew we didn't have to worry about cover it up. We got aluminum pool spray paint that has a sandy finish to it - it was purchased from our liner installer guy. We sanded all the peeled and worn areas, cleaned it all with soap and water, used autobody putty to fill in dents and knicks, then used an old license plate as a c=barrier between the coping and the brick pavers behind it. I bought attachments for the spray cans that created a more comfortable trigger holder thing at Lowes or Home Depot and sprayed the entire perimeter in about a day and change with breaks. It came out great. After 4 years though, our solid safety cover has worn through the paint where it touches and I have to touch it up. This time will be much harder though, as I don't want the overspray to hit the liner. If anyone has any pointers on that let me know! I'd really like to use a brushable paint instead of spray, as it really only needs specific touch ups but I haven't found anything yet. If you're interested I can post a photo of the spray can - we ended up using only half a case of paint.
    18x36 Spartan vinyl inground ca. 1981
    1HP Hayward SuperPump & Perflex EC65 DE Filter
    Lower Hudson Valley, New York
    Any old enamel spray paint will adhere to the aluminum plating.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Kirsten welcome to TFP!! Nice to see you over here! (please note: I didn't call you Kristen this time )
    Y'all have the right idea Clean the coping before applying the spray paint (soap and water is good but TriSodiumPhosphate is better - just try not to slop too much TSP into the pool - have a bucket of warm water with TSP - as per box instructions - sponged on and then have another bucket with clean water to sponge off the residue, I usually do 5' sections if I'm working alone or have someone come behind me to wipe the residue - 2 people makes it go quite quickly
    Once the coping has dried, use shields or tape to mask off where you are spraying the paint - DO NOT spraypaint in winds over ~ 5 mph the wind will put the paint where you don't want it
    I certainly agree with using Bondo or similar to fix any dents or dings, but then you have to wait the allotted time and sand and reclean the area before applying the paint.
    As for the straps of the safety cover rubbing the paint off every year - the manufacturers recommend placing pads on the coping, under the straps, to prevent this
    Do it once, do it right and protect your work from the ^&%^(*^* cover!
    Luv& Luk
    -Ted
    Mar 2007
    4,160
    Quote Originally Posted by rs.shadow0000
    Y'all accept the appropriate abstraction Apple-pie the arresting afore applying the aerosol acrylic (soap and baptize is acceptable but TriSodiumPhosphate is bigger - just try not to dash too abundant TSP into the basin - accept a brazier of balmy baptize with TSP - as per box instructions - sponged on and again accept addition brazier with apple-pie baptize to blot off the residue,
    _________________
    ouch!!!
    Welcome to TFP!!
    I've just gotta say
    Thank you for translating my post for those who speak your language By any chance did you write the copy for Dr. Bronner's 18-in-1 Pure Castile Soap? It doesn't matter to me As long as the message gets out to the masses in a way they can understand, all is good
    p.s. You might want to call your Dr. and re-up the lithium prescription
    Luv& Luk
    -Ted
    May 2015
    Rochester, NY
    39
    I'm bumping this old thread in case someone has an updated suggestion. Does spray paint make the coping slippery? I worry about the kids slipping.
    C.N.
    IG vinyl liner 20x40 Pool, Hayward S-240 Sand Filter and Hayward pump in basement
    Indoor Jacuzzi spa 500 gallons, Spa Marvel
    Rochester, NY
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Is there no good paint that can be brushed on? I can use a brush quickly with no tape or anything, but a spray will add a lot of extra work for me.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,384
    Cardinal systems makes a paint for this job & rustoleom flat works quit well too.
    May 2015
    Rochester, NY
    39
    I used spray paint. It has chipped some after 2 years of Rochester winters but it looks way better than before. I think a clear sealer would work well on top. They do have clear with a gripper but I haven't tried it.
    C.N.
    Rochester, NY
