Results 1 to 8 of 8
Thread: New Sharkline Venture--U-Bead liner
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Here are some of my install pics.. Sharkline Venture Hybrid 52" --U bead liner.. used local installer--he has been installing above ground pools for about 25 years.. easy to work with.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Sharkline Venture--U-Bead liner
    They hard piped NICE
    Casey's Avatar
    SW PA
    10,450
    I love that pool!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    With unions! I see one valve. Are there more?
    Kim
    Jun 2010
    Darlington, SC
    121
    There are 2 valves --but the one on the return is in the wrong place --it should have been after the SWG and before the return fitting... I will fix at the end of season and add a valve there .. So if I have trouble with the turbo cell --I can turn off the there an not worry about the water running back thru the return.
    Dolphin E10
    violet-mermaid's Avatar
    Mar 2015
    Baton Rouge, LA
    73
    Awesome!!!
    12 x 24 Buried AGP 6,800 Gallons | Intex 16" Sand Filter | Intex Krystal Clear SWG
    Hayward Thru-Wall Skimmer | TF-100 Test Kit |Hayward 900 Wanda the Whale
    May 2014
    Nevada, TX
    238
    Quote Originally Posted by Casey View Post
    I love that pool!
    THAT IS OUR POOL!!!
    its an awesome pool (when its not a swamp!)
    This is a really nice pool! I remember the excitement of getting mine installed...and getting in it for the first time. what a great feeling! Congrats!
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,450
    Quote Originally Posted by starsfan33 View Post
    THAT IS OUR POOL!!!
    Wish I could have went bigger. I love the pool.
