Results 1 to 11 of 11
Thread: Vacuuming to waste
    May 2016
    Mobile, AL
    24
    Vacuuming to waste
    I know the pool stores say to always vacuum to waste. What say you guys? Growing up we never vacuumed to waste.
    Jason - Mobile, AL
    ~ 10 year-old 25,000 Gallon IG with Spillover Spa, Plaster, Hayward S244T sand filter, Hayward pump, Second pump for spa and blower, booster pump for Polaris
    Old Polaris control system, City Water system, non-working gas heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Vacuuming to waste
    Only time I ever vac'd to waste using a manual vac was when I had excess water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I don't even have the option. My backwash valve only has two positions.
    May 2016
    Mobile, AL
    24
    So vacuum on regular filter mode then backwash when complete. Sounds reasonable to me especially if the pool is clean and clear.
    Jason - Mobile, AL
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by eublet View Post
    You might not even need to backwash unless the pool is full of stuff.
    Twice a year works for me.
    May 2016
    Hampton
    29
    I tried vacuuming to waste when I opened this year. I could watch the water level drop. I gave up, fill it back up and vacuumed on filter. I read on this forum that you can line your skimmer basket with a couple pairs of pantyhose to catch some of the fine stuff. When I do vacuum to filter my pressure rises quickly and I'm forced to backwash multiple times.
    20000 gal in ground gunite
    Hayward s200 sand filter
    Hayward 1.5up single speed pump
    May 2016
    Mobile, AL
    24
    So I just vacuumed through the filter. Water in the spillover spa became cloudy. I had. It vacuumed the spa, so I know it is coming from the vacuum water through the filter. Is that cause for alarm? I've kind of felt for the last year that the sand filter isn't working so well. It's 10 years old and I'm sure has never been serviced or had the sand replaced. I intend to do a deep clean this weekend, but honestly wouldn't mind just changing the sand and starting with a clean slate.
    Oh, and I added several cups of The Filter Fiber Stuff and had almost no increase in pressure.
    Jason - Mobile, AL
    Richard320's Avatar
    Jan 2010
    19,023
    Stuff blowing through is not good.
    What can happen is that the sand gets hardened up into the precursor to sandstone. Then you backwash and break it up into clods and if they don't settle back in the same places, you get big gaps between them where the water can slide through without filtering. That's channeling. Hopefully the filter fiber doesn;t slip through because it'll make a bigger mess.
    If the filter hasn't been opened in ten years, it might be low on sand. Who knows how many hundreds of backwashes have been done, with a little lost sand each time?
    May 2016
    Mobile, AL
    24
    Vacuuming to waste
    Well, I let the filter run overnight and this morning the pool is clear and the pressure is up from 19 to about 24 psi.
    Jason - Mobile, AL
    May 2016
    Troy IL
    476
    19 to 24 sounds like it's time to backwash...or close.
    To answer the original question, I vacuum to waste when I want to get rid of water, or if I have something nasty in my pool I want to send straight into the sewer...like gunk on the floor or something, which is not very often.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    May 2016
    Mobile, AL
    24
    My psi after a good backwash is 18-19. Goes up from there.
    Jason - Mobile, AL
