Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Proper connections
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Proper connections
    Good evening!
    I need to know if my connections are right. If not, a pic of proper connection would be greatly appreciated!
    Thanks!
    My name is Patrick Escoto
    I live in Monaca, PA
    My pool is a 33' round above ground pool. My pump and filter is a Voyager SwimPro and I also have a Nature2 VisionPro Mineral Sanitizer.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Proper connections
    So it appears you go skimmer to pump to filter to Nature II.
    So that would be correct.
    Whats leaking why is every thing so wet?
    Finally as a former Nature II owner I would get rid of it. No matter what they tell you its essentially a fancy tab feeder. Those all CYA to your pool ever time. So eventually you need to drain (unless you live in Orlando).
    We recommend liquid chlorine or a SWG. I suggest you read Pool School - ABCs of Pool Water Chemistry
    It will help you better understand whats going on with your pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Yes, proper water flow is pump, filter, swg, pool. Mineral sanitizers add metal to your water which will build up and eventually stain the pool, water, hair, fingernails, dogs all green. Look around here and you will find lots of people spending lots of time and money trying to get copper out of their pools. And copper will not sanitize your water by killing bacteria and viruses to prevent person to person disease transmission. To do that you must have chlorine in the pool. And the chlorine will also kill the algae so there is really no point in adding the copper to your pool.
    More here, Alternative sanitizers and pools--The Truth!!
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Water is from me cleaning out the pump.
    Water is completely green.
    I have 3 bags of Bioguard Super Shock and 1 bottle of algecide to add. Will this help?
    Thanks
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Quote Originally Posted by pooldv View Post
    Thanks!
    We've been told by a friend who worked for Pool City for years that straight liquid bleach is the best way to go.
    Our water is green at this time and it's 24,000 gallons so I'm not sure how to get it back to clear.
    Jun 2014
    15,246
    Patrick, you have a couple things hurting your water right now ... that mineral system is probably adding metals to your water which can change its color, and I don't see one of the recommended test kits listed in your signature (TF-100 or Taylor K-2006C). So two things I would recommend right away before we can really proceed with clarity are:
    1 - Remove the mineral system products right away to stop adding metal to the water
    2 - Obtain a TF-100 (XL Option w/ Speed Stir) or Taylor K-2006 test kit.
    Add nothing else to your water (no pool store products) other than about 1/2 gallon of regular (plain) bleach each evening. We need those test results though.
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Got it! Thanks!
    DFW, TX
    24,513
    If you can return the algaecide for a refund I would. What are the ingredients on the super shock?
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    I noticed this evening that the pressure gauge on the top of my filter tank is at 0-10. Could this be an issue as to what's going on with the water?
    Jun 2014
    15,246
    I doubt it. While the accuracy of your gauge is important to monitor filter pressure and when to backwash, it has nothing to do with the chemical balance of your pool. That's all on the proper test kit as noted above. Hopefully you will have a TF-100 test kit soon so you know for sure the condition of your water. That's #1.
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Just an FYI....
    Still waiting on the freakin' test kit! Called today and they said it hadn't even been shipped yet! Told them it better be free now since I ordered it on JUNE 5TH!!!
    I will let you know when it arrives.
    Thanks!
    DFW, TX
    24,513
    Where did you order the TF-100 from? TFTestkits.net has it in stock always and will ship within 24 hours.
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Ordered it from pool supply world and it just came today!
    Ordered it JUNE 5TH!!!
    So, now that summer is half over, I'm ready to figure out what is going on with my water! Most of the "swamp" green color is gone but still cloudy.
    I'm ready for any and all instructions on where to start.
    Jun 2014
    15,246
    Alright! Post a full set of results for us.
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Uhhhh......not sure which to do first!
    Jun 2014
    15,246
    Doesn't matter which order but do them all for us. You can follow the Pool School - Extended Test Kit Directions page if you need help. We need to see them all:
    FC
    CC
    CYA
    PH
    TA
    CH
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    OK
    So I did CH and Ph first
    Ch is in the 5-10
    Ph is 7.5
    Jun 2014
    15,246
    pH is good. But with CH, you are supposed to mix the solutions and come-up with a number after counting the drops that you multiply by "25". So we would expect your CH result to be something like 200, 250, 375, etc.
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    FC is 6.5
    CC is 1
  20. Back To Top    #20
    escoto111's Avatar
    May 2016
    Monaca Pennsylvania
    17
    Sorry
    Cl is 5-10
