Thread: chemical weight in pounds and ounces
    Jul 2015
    Connellsville, PA
    1
    How do I get Pool Calculator to calculate in pounds and ounces, especially for chlorine addition? Maybe I'm missing it, but it shows but does not calculate the dry weight. THANKS!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: chemical weight in pounds and ounces
    For what chemical? It will only list volume for bleach based on trade % and only lists weight for solids such as dichlor. Are you using Pool Math: http://www.troublefreepool.com/calc.html or the outdated Pool Calculator?
    Also... welcome to TFP!
    Isolated Spa - 345 Gallons
