Thread: Fc levels and robot use
    Dec 2015
    Newington, Connecticut
    113
    Read some warnings in a dolphin manual an states that the chlorine levels should not be higher than 4.0 ppm during use. I'm assuming for corrosion issues but most of us are maintaining higher levels than this.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Donldson's Avatar
    NW Ohio
    2,917
    Re: Fc levels and robot use
    Everything says that. It assumes a zero CYA level. Consider SLAM level as a maximum and it will run just fine.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,521
    Agreed. That is the typical recommendation on everything. With CYA in the water, it is safe at much higher FC levels.
    Dec 2015
    113
    Thanks everyone
