Thread: Another homemade pvc aerator using a spa jet
    banditig's Avatar
    Sep 2015
    Ohio
    466
    image.jpgimage.jpgTo lower TA. I put a union on end to screw into return so it's also a fountain. I can run it without air also so the PH doesn't get too high by using the shorter pipe.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Another homemade pvc aerator using a spa jet
    A skinny pool noodle and a hose clamp could turn that into a swell water cannon.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    That sounds fun!
