Thread: PH spike???
    May 2016
    MD
    195
    PH spike???
    So all I have added over the last 2 weeks was bleach... and slowly the numbers of PH have gone from 7.2 to 7.8.
    I have a slide and a little water runs off of it, the waterfall effect...?
    FC is at 9
    TC 9
    ALK- 220
    CYA 85 ish
    PH 7.8
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Aug 2010
    Dallas, TX
    4,052
    Re: PH spike???
    Any aeration, including water going down your slide, will increase pH. With your TA (Alk) at 220, you are going to have swings like that. If you got it down to around 80, these swings would be reduced.
    May 2016
    MD
    195
    Re: PH spike???
    Ok. figured as much...
    working on getting everything down... takes time with a well... not sure how you know when it will run out of water... seems like it never will...
    Aug 2010
    Dallas, TX
    4,052
    Re: PH spike???
    Lower your pH to 7.0-7.2 with muriatic acid. Keep the water going down the slide for aeration. When pH gets to 7.8, repeat.
    Pool School - Lower Total Alkalinity
