Thread: How many hours a day should I Run pump?
    Dec 2015
    Redding, CA
    22
    How many hours a day should I be running my pool pump? The temps are about to climb into summer weather which is 95-115 for the next few months.
    22,151 gallons, IG, Pebbletech, Pentair Quad D.E., Pentair IntelliFlo Variable Speed
    Built in 1993 then pebble tech applied in 1999, TF100 kit w/ Speedster, Basic K-1000
    Mod Squad pooldv's Avatar
    DFW, TX
    24,459
    Re: How many hours a day should I Run pump?
    I run mine at 1100 rpm for filtering, skimming and making chlorine with the SWG. It only uses 150 watts. 2-3 hours AM and again in PM is probably sufficient. If the pool stays clean, good. If not increase run time a little until the pool stays clean.
