Results 1 to 11 of 11
Thread: Pump issues no circulation from filter
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    This is a pool at hotel just took over maintenance looking at the system pump running but no circulation in the skimmer no movement
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pump issues no circulation from filter
    Earl,
    I think the bottom picture is a skimmer? Is there water in it?
    All the valve's look to be open, there is a SWG on there.. I do not see any pressure after the SWG on the pressure gauge.. but there is pressure in the filter (unless that is broken) Is there a valve or blockage between the filter and the heater/SWG ?
    What is the sand filter selector set to? filter?
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Yes I meant skimmer lol
    sand filter selector is set to filter. The heater is broken
    this is the gauge between the pump and the main drain and skimmer valve
    mas985's Avatar
    Pleasanton, CA
    11,737
    Remove the skimmer basket and see if there is a plug in the pipe.
    Also, on the return side post SWG, there is a flow meter and pressure gauge, what do they read?
    Mark
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    No plugs in under the skimmer basket.
    Pressure gauge reads 0 and flow meter reads 80
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by Earl Cox View Post
    I don't think that is possible so the pressure gauge is probably broken.
    It looks like the suction valves are set properly in the picture so my only suggestion is that there might be something blocking the skimmer line. To test this theory or perhaps clear the blockage, can you turn off the other suction line so the skimmer is the only thing that is active? If the filter pressure goes down a lot or you get a lot of air in the pump basket, the line is probably blocked.
    BTW, where do the two vertical pipes go?
    Mark
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Not sure what the 2 vertical pipes leads too but it goes to the overhead. I closed the main drain valve got some circulation in the skimmers pressure gauge jumped up to 7
    mas985's Avatar
    Pleasanton, CA
    11,737
    Which pressure gauge jumped to 7 PSI?
    The gauge on the yellow pipe should be a suction gauge which reads in-hg.
    BTW, do you know the model # for the pump? It looks like a Sta-Rite but I was wondering what the model # might be.
    Also, how far below or above is the equipment from pool water level?
    Mark
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    The gauge at the yellow pipes. Yes the gauge reads in in-hg
    Pentane Pump model #168452
    Equipment not too far rom pool
    mas985's Avatar
    Pleasanton, CA
    11,737
    Do you mean Pentair? I think that is the motor number but good enough for an ID.
    Best I can tell, things are working as they should. The pump is an up rated 1 HP so it is not very big and the pressure and suction will not be all that high with that pump. The flow rate and head loss perfectly match a Challenger pump's head curve B which is for the up rated 1 HP. So that looks good too.
    If the skimmer was plugged, the suction would be much higher than 7" hg. It just may be that you can't tell the water is going into the skimmer. You might try throwing something that floats in front of the skimmer and see if it gets drawn in.
    Mark
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    It's auto correct bad phone lol
    Yes pentair Triton II TR-140
    There are 2 skimmers to this pool
