Thread: Maintenance on Jandy Heat Pump AE3000Ti
    Central Connecticut
    159
    I am thinking about having my heat pump looked at to make sure it runs at full efficiency. I understand it uses a gas or refrigerant. Maybe time to recharge. I am not having any issues with the heater, but after 6 years, I am not sure it is heating the way it should. Has anyone had their heat pump recharged? Know of such a thing?
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Maintenance on Jandy Heat Pump AE3000Ti
    Yes, it is basically an air conditioner compressor, any HVAC service company can check it and add freon if needed.
    dauntlesst's Avatar
    Mar 2016
    Nashville, TN
    2
    I had the same model recently installed for my pool by my HVAC folks (had to talk them into it by explaining it was already plumbed and wired!) We had a Jandy heat pump prior to that which died after ten years.
    Not only did they install it but the company added it to my maintenance plan with them with a discount.
    Concrete with acrylic panels, 16 x 32 feet, Paramount in-floor cleaning systems w/ single speed pump, 2 speed Jandy pump for main drain/skimmers, Intermatic electrical controller box w/ two timers, Jandy AquaPure SWG, Jandy Cl580 Filter Jandy AE-Ti Heat Pump, Completed Late Spring 2006
