Thread: pump times?
    May 2016
    San Antonio
    14
    pump times?
    Hi there!
    wondering how long you guys recommend running the pump per day?
    thanks!
    9,500 gal, in-ground, gunite
    Hayward 1HP pump, filtration system
    killed the auto chlorine system; using bleach!
    San Antonio, Texas
    (hard water)
    Jun 2014
    15,298
    Re: pump times?
    It really varies for every pool based on many different factors, one of the most important being surface debris removal to the skimmer(s). You might like to read the TFP Pool School - Determine Pump Run Time page. When at a total loss of where to start, run the pump for about 8 hours and then adjust from there based on your pool's response and cleanliness.
    May 2016
    San Antonio
    14
    Re: pump times?
    Hi-
    thanks! Didn't see that one.
    Was a new build, so we ran it 24/7 for a bit, now are down to 16...
    hubby wondering about the electric!
    Will go read up.
    thanks again
    San Antonio, Texas
    (hard water)
    Aug 2010
    Dallas, TX
    4,052
    Re: pump times?
    You can probably get away with half that.
    Your auto-chlorine system is probably a bigger issue than your pump if it uses tablets.
    May 2016
    San Antonio
    14
    Re: pump times?
    Learning that!
    Will stick with them for the moment, since we just bought a giant bucket of them, and have a trip or two coming in the summer...
    Going to read some more today. Cutting back to 10 for now.
    Put one gal of the acid in yesterday, and the pH seems perfect now.
    The water will always be hard...
    thanks!
    San Antonio, Texas
    (hard water)
