Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Question about chlorine lock
    Sep 2015
    York pa
    12
    Re: Chlorine Lock Causes?
    I am also having an issue with chlorine. Last year we could not keep the chlorine level high enough to show up on a test. The CYA levels were fine. This year we drained some of the water but still cannot get a chlorine reading to last more than a couple hours. What do you suggest?
    Finally got my test kit. Result from yesterday are:
    CYA 80
    FC 7 (after adding 2gal bleach)
    CC 2.5
    ph 7.5
    TA 180
    CH 400
    This morning the readings were:
    FC .5
    CC 2
    The water is crystal clear and there is no algae. Do we need to keep the chlorine level at 6 as stated in the chart for it to be safe to swim in?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: Question about chlorine lock
    Something's eating your chlorine. It's either organics or sunlight.
    Organics include things like leaves and twigs, algae, and the A-word: Ammonia.
    A seriously green pool will devour chlorine like nobody's business, but you ought to be showing something on the test if you checked it within an hour of adding chlorine. A pool with Ammonia makes a green pool look anorexic. It'll eliminate chlorine as fast as you can pour it in the water.
    The place to start is with some test results. Also, tell us where they came from (what kit) and what kind of pool and equipment you have, and what the water looks like.
    38,524
    Welcome Back! I moved this question into its own thread.
    I suggest you read all 11 of the responses in the thread you started last year and then see if you still have questions:
    Chlorine lock...is it real and what's the remedy?
    Jul 2015
    Central Valley CA
    1,109
    It is probably ammonia take a look at THIS thread. Also what kind of test kit do you have others will be along shortly and it will be helpful if you can post some test results.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    30,432
    bkmomof4,
    Welcome to the forum.
    As you continue to read, you will find that we teach that you take the bull by the horns and learn to manage your pool. In short, "Stay out of the Pool Store"
    Anyone talking with you about chlorine lock is either terribly under educated or simply doesn't want to learn.
    Chlorine Lock is a myth that doesn't exist. If you decide to learn what we teach here at TFP, we will promise you will end up with crystal clear water and a whole new understanding of how this all works
    You will find it increasingly difficult to follow our advice and then follow pool store advice as well. The two simply don't mix well.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to TFP Bkmomof4
    Chlorine lock should end up on myth busters so it can be debunked. IMHO, It's something the pool store person will say when they don't know what's going on. Usually followed by a 30 to 60 bottle of "try this".
    A photo of the water would be helpful as would adding your pools and equipment information in your signature as outlined here: Pool School - Getting Started
    The more information we have the more accurate and helpful the response
    As stated above it's more likely something is eating your chlorine. Need to know your CYA level and what you are using for a chlorinator and if it's your test results or you are having the pool store test for you.
    Solar Blanket, Well Water, Borax Added. 76
    Sep 2015
    York pa
    12
    Finally got my test kit in the mail. Results from yesterday are:
    CYA 80
    FC 7 (after adding 2gals bleach)
    CC 2.5
    ph 7.5
    CH 400
    TA 180
    This morning results were
    CC .5
    CC 2
    the water is crystal clear and no algae. Do I need to keep the chlorine level at 6 as stated on the chart in order for the water to be safe for swimming?
    25K, IG vinyl, sand filter, 10 yrs old, TF100 test kit, elec htr
    Aug 2010
    Dallas, TX
    4,052
    Check your math... CC of .5 and CC of 2 at the same time? I think you mean FC of 2 and CC of .5. If you had an FC of 7 last night and FC of 2 today, you have something organic growing in your pool. Was your initial FC of 7 taken near dusk, or earlier in the day?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Quote Originally Posted by RobbieH View Post
    Agreed. Just because water is clear doesn't mean something isn't growing in it sight unseen. I had clear water last year after an oops on my part that was consuming 3ppm FC overnight...
    Support the site
    Sep 2015
    York pa
    12
    The initial test was taken around 5pm. The morning results were as written
    FC .5
    CC 2
    Aug 2010
    Dallas, TX
    4,052
    OK, that's a clear indication that you have algae. Time to SLAM:
    Pool School - SLAM - Shock Level And Maintain
    Sep 2015
    York pa
    12
    Per the chart I'd need to reach a 31 chlorine level to slam. My CYA is 80. Probably not realistic. There is no visible algae growth. Is it safe to swim in?
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by Bkmomof4 View Post
    Do you mean it is not realistic to fix the issue?
    Personally, I will not swim in a pool that will not hold FC, or one that has algae.
    38,524
    Why is that not realistic? That is exactly what you need to do until you pass the 3 criteria to stop. You are currently only passing 1 of them.
    Jun 2011
    Long Beach, CA
    2,790
    You have nascent algae. There is just enough chlorine being added to keep the algae from blooming, but not enough chlorine to kill off all the algae.
    Believe me, you need to complete the SLAM process or you will go through 10 times more chlorine than you should. Been there done that.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by ping View Post
    We all have learned this the hard way at least once I think.
    Richard320's Avatar
    Jan 2010
    19,073
    Just a thought... have you added any non-chlorine "shock"? That's stuff like Chlor-free and Oxone. MPS will give a false high CC reading.
    If the pH is in range and the FC is above minimum for the CYA level, then technically I guess the pool is safe to swim in. People have been swimming in rivers and lakes and ponds with no test results for centuries and haven't been dying from it. But if that CC is CC and not interference, expect skin irritation and burning eyes.
    Taking FC up to 31 is not so difficult. It's just a matter of emptying some jugs. If you get a good kill on whatever is growing -- and it can't be much if the water is clear -- then maintaining it shouldn't take any huge volume of bleach. It's just getting it up there initially that looks so daunting. And if it does have an unquenchable thirst for bleach, then it's just a matter of time before the pool turns to a swamp.
    Also check for algae lurking behind lights and stairs and inside ladders. You still haven't filled out your signature so we have no clue what we're dealing with.
    Sep 2015
    York pa
    12
    Thanks Richard 320. What else would you like to know that is not in my signature?
    Jul 2013
    North Canton, OH
    192
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
  20. Back To Top    #20
    Sep 2015
    York pa
    12
    I have been slamming since Tuesday. This morning(Saturday) my FC had a 2.5 loss overnight and the CC was 1.5. I followed the prep instructions to the letter. I have added at least 40 gallons of bleach. Am I doing something wrong? This seems extreme considering the water looked good before I started.
