Results 1 to 7 of 7
Thread: lil shark Vac - Hook Up Question
    May 2016
    TX
    28
    Re: Vacs for Above ground pool what do you have
    Just bought lil shark. How can I hook it up in Intex pool? No skimmer on wall
    18/48 Coleman above ground. Intex sand pump and Intex saltwater system
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: lil shark Vac - Hook Up Question
    you will need to add a port or valve in your plumbing to connect it up
    Earl and Jeff did theirs and posted in this thread how to do it
    I got the Intex Automatic Pool Cleaner - Page 2
    May 2016
    TX
    28
    Thank you, we got the little cutie all setup. He's works great
    May 2016
    Walkertown, NC
    28
    What are you guys using to store and keep your hoses straight? I saw this but thought it was expensive for t=what it is.
    HoseHanger PRO
    24' AG Round 12,700 Gallon ( w/ 45" level) Vinyl Liner
    Pentair Sand Dollar SD-40 Sand Filter w/ 1.5 HP 2 Speed Pump
    Taylor K-2006 Test Kit
    Walkertown NC ( North Central NC 30 miles from Greensboro, NC)
    Pool gets 6-7 hours of sun on a sunny day
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Actually I keep mine inside the pool all the time, don't bother me, great Lil Vacuum... 😊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    May 2016
    Walkertown, NC
    28
    Looking for a solution for when i take it out.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    If I were to put it outside, I will use the original box
