Thread: Aquabot pura4x Flashing Both pool size and wont run
    Jun 2015
    Oak Forest IL
    20
    I'm guessing this is a common issue with this thing. ITs only 1 1/2 years old and it looks like the power supply is broken. Has anybody ever fix this issue them selves or know if aquabot will fix?
    rajung's Avatar
    Mar 2015
    Iowa
    187
    Re: Aquabot pura4x Flashing Both pool size and wont run
    Mine did it a couple weeks ago on my Rover.
    May not be the same issue but I created it by mistake.
    Filter bag I used was too soft and it partially worked itself into the square openings and jammed the motor.Luckily it didn't damage it.If you haven't, check to see if the motor turns by hand and not seized.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
