Thread: Hi all checking in from Spain
    Shaun007's Avatar
    May 2016
    Spain
    2
    having troubles with Algee forming on tiles but only a small amount , pool has been shocked and used alacide. Perhaps weekly wall scrubs are in orders?
    Ps I'm a neebie to pool care
    Jun 2014
    14,966
    Re: Hi all checking in from Spain
    Hello Shaun and welcome. Yes, I suspect some scrubs are in order if the algae is at or above the waterline. Grab a brush and some bleach and hit it good. If you see cloudiness or green below the waterline, you'll want to increase FC levels and do a "SLAM" as noted in my signature below. Ordering the proper test kit (TF-100 or Taylor K-2006) would be a very good thing to do if you can. Have a nice day.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcom to TFP
    We have seen people from spain and they have always have a problem ordering a good test kit, ebay has a K-2006 that can be ordered worldwide but they are very expensive... it does the best at telling you what your water is doing
    Shaun007's Avatar
    May 2016
    Spain
    2
    Thank you
    I will check eBay thanks for the info
    Shaun
    8 x 4 Mtr in ground pool
    Hayward filtration system with glass medium
    48000 gallons chlorinated water
    Casey's Avatar
    SW PA
    10,421
    Welcome! Increase FC and brush your pool weekly!
