Results 1 to 12 of 12
Thread: PSI on Hayward 1 HP Pump/Filter
    FunInTheSun's Avatar
    May 2009
    Whiteman AFB, Missouri
    46
    Is it right that the PSI gauge on our Hayward pump is at 0 while running? I've turned the unit on/off and the gauge doesn't move.
    I've included some pics of our unit. Thanks!
    Amy
    24' round, Vinyl, 4ft Deep AG pool 13,500g
    1 HP Hayward Pump
    Finally having Summertime FUN!!!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: PSI on Hayward 1 HP Pump/Filter
    Probably not. Try a new gauge. They fail if a leaf falls too close to them.
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    I'm assuming you have water flowing out of your returns? If you do then I'm sure it's just a bad gauge.
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    May 2009
    46
    ETA:
    I was reading the operating instructions on the filter which says to prime the pump but we are unsure of how to do this?
    Where can I buy the appropriate sand (0.45mm - 0.55mm for the filter, I have no idea how much sand is in there or what condition it is in. I'm assuming it's the original sand that came with the installation in 2007, how often does that need to be replaced?
    Tomorrow I will have to go down and follow these instructions, shame on us for not reading them earlier.....
    Amy
    1 HP Hayward Pump
    SW Indiana
    9,198
    You shouldn't have to prime an AG pool pump.
    Sand lasts for many years. As long as it works, don't worry about it.
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Like Johnt said you don't need to prime an above ground pump,gravity will do it for you.
    Did you have any water flowing when you started the pump?
    Hayward 40 GPM pump
    May 2009
    46
    Okay, thanks for the info on the priming and yes we had water flowing when we started the pump.
    Amy
    1 HP Hayward Pump
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    I bet it's just your gauge. You got to love it when it's a simple fix.
    Hayward 40 GPM pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    With the pump and AG pools, gravity from the skimmer to the pump is usually enough to fill the pump basket with water....you can see it thru the clear plastic lid. If it's full with water, the pump is "primed", if you see the water leave the basket and it fills with air then you have a suction side leak, check your connections.
    Also you want to make sure the air is not trapped in the filter, so there is a air bleed valve at the top of the filter, you open that and hear air escaping and then a stream of water shoots out (this is with pump running - you WILL get wet. ) Do you feel water coming out of the return when the pump is on? If all of these things are happening like described then it's probably just the gauge.
    Probably still a good idea though to open up the filter and check the inside...make sure there is sand...
    May 2009
    46
    I do see water going through the pump basket, no water/air leaks. I will have to check the air bleed valve in the morning, I don't remember seeing that function on there but will doublecheck.
    There is water coming out of the return, full force.
    So, it sounds to be the gauge, I love the sound of that, how do I fix the gauge? Does it need to be replaced?
    Thanks again for all the knowledge!
    Amy
    1 HP Hayward Pump
    The gauge gets replaced. They are fairly inexpensive, should be between $5 and $10. These gauges rarely last more than a couple of years.
    May 2009
    46
    Is there a stickie where I can read up on this ~ we are DITY'ers so if we can attempt it ourselves it would be GREAT!
    Thanks so much!!!!
    Amy
    1 HP Hayward Pump
