Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: I've Failed - Black Algae - Clear Water
    TFP_wanna_be's Avatar
    Orlando, FL
    129
    Hello... I'm back - I fell off caring for our pool and have been on a yo-yo cycle of green and blue...
    Few weeks ago, I had a dark green swamp. I mean, it was bad and with air bubbles from my system, it was a mess... Wife and 3 kids say get it together dad...
    Found the air leak (o-ring on basket drain) purchased new grids 36sq and cleaned the filter twice. We have a outdoor dog (lab) and a large sand box.. Kids and dogs add sand to the pool.. Lots of sand!!
    I think I've got the pool coming around and come back to see what the BLACK SPOTS are on the 6yr old surface. Never had any issues until I let it get swamp green...
    I've been using acid and CL running the pump a lot to get this progress...
    Total fail here - My numbers...
    Ph 7.7 (drop test)
    CL 5.0+ (drop test)
    TF100 kit
    CYA approx 100-110
    TA 60
    CC 0
    FC 2.5
    CAL 600
    Trying to attach pictures - where do I start to attack this algae?
    Thank you!!
    Kevin
    My Intro Page: tfp-wanna-be-checking-in-t27499.html
    20K Gal IG Pool - Resurfaced 11/14 w/ Super Blue Diamond Brite
    I test with TF-100 and SpeedStir
    1.5Pentair / 36sq DE filter
    Polaris 380 (love this thing)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: I've Failed - Black Algae - Clear Water
    Welcome back!
    Please add your location to your profile so it shows up over there <---- so that we can make an appropriate recommendation for your CYA level.
    Aug 2014
    Northern IL
    4,615
    To confirm black algae, scrape some of it with your fingernail and put the scrapings on a piece of white paper. If the smudge is green, it is likely black algae. See: Pool School - Black Algae
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Do the fingernail "test" like Marian said, add your location like pooldv said. THEN drain some water to get your CYA down. Use pool math to see how much you need to drain to get it to where you need it. I would take it down to 30 since you are going to need to SLAM the pool if that does turn out to be algae.
    Lets get that cute baby in the pool!
    Kim
    Orlando, FL
    129
    I'm on my phone so I can upload pictures... Thanks! That baby picture is now a 6yr old, but have a new baby to get in the water. And trying to have a party in a week or so (yikes)
    I'm located in central Florida - updating my profile soonest
    I read over the pool school for the black algae and wasnt able to scrap any from the sidewall. I've been brushing it with a basic nylon brush for weeks in part to get the green away.
    I did find an area on the grout line and it appears to pass the test. Looked black in the water and when smeared, is a rich green.
    I'm going to re-read some pool school.... I only know that if I approach in the wrong order, I won't get the results. Thanks again!!!
    Orlando, FL
    129
    Okay.... Based on the pool calc with a 20K pool, it says drain 70% of the water for a goal of 30
    I'm going to double check my CYA numbers. This morning... Thank you!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by TFP_wanna_be View Post
    60 CYA is fine for Florida. No need to go wild with the draining. Besides, you don't want to float your pool.
    Have you considered a stainless steel pool brush? I think your plaster is cured by now so it'll be safe.
    DFW, TX
    24,497
    Agreed, I'd only drain about half. Then SLAM and brush the heck out of it a few times a day.
    Orlando, FL
    129
    Forgive me.... I don't seem to follow the SLAM
    I do have:
    Free and clear
    Clean charged filter
    Ph is 7.7 (I can tune it in)
    Can run pump 24/7
    My current CC is 0 (preferred post SLAM)
    Water is clear
    12hr FC Test and no change in FC, still 2.5
    I get the replacing water. I can refill with city or well water. Current pool water is well water.
    This will get my CYA to 60...
    With my shock number of 24, do I change my goal to 24? (894oz) of CL...
    On my way for CL & SS brush.... Be right back!!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Brushing is key... brush, brush, brush! Maintain a slightly elevated chlorine level for a month or so as well.
    CAM00102 by Annie, on Flickr
    After:
    CAM00106 by Annie, on Flickr
    Yes, change your goal to 24
    Orlando, FL
    129
    Now that is motivation!! My new SS brush is getting to work here shortly...
    So I'm clear about the SLAM with a goal of 24.
    With the pool full ensure PH is 7.2-7.5
    Then drain off half the pool water
    Refill water
    Hit with 900oz of liquid CL
    Question:CL all at once or 120oz every few hours?
    Orlando, FL
    129
    Wow...!!! The brush is amazing.. Huge difference....
    I drained the water and going to add CL and refill this evening.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Just to be sure, refill first, then add chlorine
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    38,295
    And you can add all the chlorine at once to hit your target. Pour slowly over a return jet in the deep end.
    Orlando, FL
    129
    Thanks!! I went back and re-read the SLAM... Still a little frazzled, but I'm pressing on!!
    My kids love the half drained pool...!!! I'm trying to more pictures to up load.
    My hands feel VERY chalky from the water...
    Untitled | Flickr - Photo Sharing!
    38,295
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    May 2016
    Orlando/Florida
    24
    Here in Orlando also, just completed a Slam, even got a chocolate Lab. Mine won't get in the pool though. Most well water around here is very high in sulfur, are you using it or city water. If you have hose bib hooked up to irrigation meter, I would use it.
    I use a combination brush, wonder if the S/S would be good for Stonescape finish?
    20' x 32' (22,200 Gal.), I/G Stonescape finish pool, Pentair Intelliflo VF 3 Hp pump, Pentair CC200 filter, Pentair Intelliflo IC40 SWG, built 2014, TF-100 test kit w/ Speed stirrer.
    Orlando, FL
    129
    Great! I just became a Jr supporter... Like to include pictures and face the facts, there are costs with running this site...
    I'm now filling... Using well water. The original refill after resurface was well water. I was concerned, but it seemed fine. This time I want to have more comfortable water - I was merely keeping it clear, but it wasn't comfortable for the kids. Swim one weekend and shock the next weekend... It's a process I guess - I hope I'm getting closer to taking better care of it.
    DFW, TX
    24,497
    You are definitely in the right place for great pool water! I haven't ever shocked my pool or missed a single day of swimming that we wanted to swim since the day we filled the pool in 2012. Also haven't ever drained it. TFPC rocks!
    Thanks for supporting TFP!
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,525
    I have just the thing for you!
    I have this printed out and by my test kit. It has become second nature now but I still refer to it every once in a while to make sure I did not miss something.
    Kim
