Results 1 to 9 of 9
Thread: First time I cleaned my filter by myself, it looked like this...Is this normal?
    Apr 2016
    Houston, TX
    60
    This is what my filter looked like when I cleaned it myself for my first time on 2/27/16. Is this how a dirty filter is supposed to look?
    IG, Plaster, 15,000 gal, Free-form (angular)
    Pentair FNSP 48 DE filter (48 sqft)
    Hayward SP3010X15AZ pump with 1.5 HP motor (installed 3/2015)
    Rock waterfall, large live oak shades half the pool
    Re-plastered April, 2017
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,488
    Re: First time I cleaned my filter by myself, it looked like this...Is this normal?
    Looks pretty normal to me.. How many times do you backwash before you tear it down for a good cleaning.
    What is your normal clean pressure and at what pressure are you backwashing or cleaning?
    Edit.. have you put it back together yet? First time took me an hour and I thought I was going to have to call someone. Getting all the grids to line up in the right place and at the same time can be fun...
    38,274
    That looks pretty typical to me, maybe a few too many backwashes and too much DE on the recharges before you broke it down.
    These might be helpful:
    DE Filter Cleaning Tutorial
    Use and Care of DE Filters
    Apr 2016
    Houston, TX
    60
    Quote Originally Posted by Jimrahbe View Post
    I never did my own backwashes before this filter clean. I entrusted all maintenance to a pool guy for 2.5 years (as long as I've been living in this house with my first pool) and just last month cut ties with him. Before I did this filter clean, it was operating at 30-35 psi (well past the "clean filter" indicator mark ). After the cleaning, I added 10 quarts of D.E. thru the skimmer. I believe that is the correct volume of D.E. to fully charge my filter, but correct me if I'm wrong.
    The pressure was 10 psi after the cleaning. I've backwashed 3 times since that 2/27 tear-down, each time when the pressure nudged past 20 psi. Post-backwashes, pressure drops back to ~12 psi. Also, every backwash I do is for 1.5 minutes, then I add another 5 qts D.E. thru the skimmer. Please let me know if that's not correct.
    When I put the filter back together, everything fit into place without any hassle (guess I got lucky ). The most annoying/concerning part was the extremely loud squeaking sound that came from every quarter turn of my crescent wrench in tightening the barrel nut back onto the T-bolt. Is that sound normal?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    After a fresh cleaning, you do a full charge based on the manual. After a backwash, you add 80% of the full charge.
    I've seen much worse.
    Yes that wretched sound turning the bolt is normal
    Apr 2016
    Houston, TX
    60
    Thanks, I'll check those links out!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    It's not all black inside. You could have squeezed another month out of that!
    Everyone else has said it all.
    JoyfulNoise's Avatar
    May 2015
    13,195
    White lithium grease (WD-40 brand is ok) on the bolt threads helps reduce the sliding friction on the nut and t-bolt. I only hear the squeak when I get to the tightest point on the turn.
    I would suggest far less with every backwash. I have a Pentair QuadDE-100 filter. I use 10lbs on a fresh recharge and never more than 4 pounds on a backwash. That is more than enough DE. You backwash far less than 50% of the DE (especially with only a 90sec backwash), using more than 50% of the fresh charge value will lead to excess DE sitting wasted in the bottom of the filter.
    Matt
    Apr 2016
    Houston, TX
    60
    Thanks for the tip! I'll definitely cut it back.
