Results 1 to 8 of 8
Thread: Ladder Hole repair?
    May 2016
    Schaumburg, Illinois
    32
    Ladder Hole repair?
    Is there anyway to repair this where the bolt and clamp broke off. I am kind of at a loss. Thanks!
    Shared album - Andy W - Google Photos
    Kayak? 19' x 34' 21k Gal. Kidney | IG | Fiberglass Panel Sides with Concrete Bottom | Hayward Pro Series Sand Filter S244S, SP710X62 Vari-Flo Valve | Hayward Super Pump 1 HP Single Speed SP2607X10 | Built 2004| TFTestkits TF-100 | Aquabot Rapids 4WD, Jandy Lite2 Gas Heater, American Products Auto Skimmer and Auto-Fill, Rayner Safety Cover | City Water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Ladder Hole repair?
    There doesn't look to be an easy way to repair that without some welding... Probably will have to remove the anchor and replace. Some anchor sets are linked together under the concrete by a bar to set the spread between them, so you may have to remove them both by cutting out a channel between them. You might be best served replacing both as the other might not be far behind. This means a concrete saw job, removal of the old, installation of new and pouring new concrete in the channel. Going with a bronze set may lengthen the life of the new set.
    Isolated Spa - 345 Gallons
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    What about drilling in and using one of those threaded bolt extractors?
    If you do try that, squirt some penetrating oil on it first a few times and let it sit over night to help get it loose.
    oops just realized you meant the concrete hole is busted out..
    disregard.
    Dolphin E10 Cleaning Robot.
    May 2016
    32
    Quote Originally Posted by JVTrain View Post
    So, easy. Right
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by andwhite1 View Post
    So, easy. Right
    Not an easy fix if you can't figure out a repair-in-place option, that's for sure. Plus the likelihood that the new concrete strip over the anchors won't match the old concrete. Maybe another member has a better idea.
    Scout101's Avatar
    Aug 2015
    North Kingstown, RI
    161
    Mine's held in with a wooden shim on one side, seems to work great. And much cheaper
    IG Vinyl, free-form 25' x 40', 25,000 gal., Hayward 1-1/2 hp Superpump, Hayward S310T 500lb. Sand filter, AquaLogic T-Cell 15 SWG and Automation, Hayward H300 Milivolt 300k btu NG heater, TF-100 Test Kit w/spinner
    May 2016
    32
    Quote Originally Posted by Scout101 View Post
    Ahhh. That is a great idea.
    Scout101's Avatar
    Aug 2015
    North Kingstown, RI
    161
    Credit the pool guy with that one. I had one missing bolt, and was asking him what size I should go check my parts bin for, and he just whipped out a shim, hammered it in, and snapped off the extra. Just as easy, and holding rock solid.
