Results 1 to 9 of 9
Thread: Intex 15' replacement pool wall
    Does anyone know of source for purchasing a replacement pool wall for 15' Intex Ultra frame? I have the tubing frame, just need the pool wall.
    Thanks
    38,235
    Re: Intex 15' replacement pool wall
    Ultra Frame pools do not have walls. The vinyl pool just hangs on the frame.
    Jul 2014
    Oakbank, Canada
    389
    Just as cheap to buy the entire new pool unfortunately
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Casey's Avatar
    SW PA
    10,418
    If you still have the old liner, you can drop an above ground pool liner in it like many others have done.
    Thanks.....the vinyl "wall" is the item I need. I do not have the orig one.
    Thanks.....I'm beginning to think this is the way to go.
    Thanks....unfortunately, I do not have the old vinyl. Guess it's new pool time.
    38,235
    The vinyl "wall" is basically the entire pool
    I think you are going to have to buy everything new ad I am not sure the parts are worth the savings or even if they are available.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    It's called a liner. You can get replacements directly from Intex: Search results for: 'liner' - Intex
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    38,235
    Good stuff Jeff!
    Jul 2014
    Oakbank, Canada
    389
    They have come down quite a bit in the last couple years, well worth to order one at those prices. A 16' Ultra (same as mine and the one your asking about) is only $152, and they have stock. 16´x48 ROUND ULTRA POOL LINER - Intex
    Called a 16', but actually measures only 15-ish.
